Thought i had this over heating sorted..
Gazza2005au
VT series 2 Calais V6 just done a radiator flush on saturday, replaced the thermostat, changed relays
If i drive around 60kph and under the temp gauge sits just below half and doesnt move
Soon as i do 70kph the temp gauge goes up to one line below the red / hot line
Both thermo fans are working
Do u think a blocked radiator? There is no coolant leaking, or faulty temp sensor? Would a faulty temp sensor trigger the fans to turn on?
No coolant in the oil
Lex
Geelong Victoria
VT Executive S1 V6 6 speed Auto Wagon
Did you bleed the air out of the coolant system?
shane_3800
35
places
vr commo
Have you checked the thermostat?
Is it the same as before the radiator flush?
Gazza2005au
Yeah i installed a new tridon thermostat i also boiled the old thermostat and that too opened up around 9-10mm
Immortality
Staff member
Sth Auck, NZ
Bleed it again.
Gazza2005au
I pulled the thermostat out and cleaned the bleed hole next to the thermostat, i used a coke bottle in the radiator hole, filled her up bled her than started the engine warmed her up than turned the heater and fan on high than bled the air again
Took her for a drive within 1km of going 70-80kph temps went up to half way, i turned around and came back just doing 70kph and she peakedat 3/4th temp again i had to turn her off before she sky rocketted at the lights
Left her off for 2mins than restarted and she was reading just below half again
Im guessing i need to replace the head gaskets or get the heads checked for cracks?
3 days ago the coolant bottle was on the full mark, this morning there was no coolant in the bottle and radiator needed a top up
Immortality
Staff member
Sth Auck, NZ
With the radiator cap off and engine running and up to temp are there bubbles coming out of the radiator?
Immortality
Staff member
Sth Auck, NZ
How old is the waterpump?
Has it always had coolant/rust inhibitor used?
Thermofans turn off when you go faster than 64km/h, the fact that temps go up when you get up to 70 suggests there is either a airflow issue or coolant flow issue.
