panhead
- Jan 17, 2016
- 3,155
- 4,497
- 113
- Location
- NSW Central Coast
- Cars
A throttle controller changes the pedal ratio basically, so if the engine revs to 3000rpm with 5mm of accelerator pedal depression in neutral stock, with a throttle controller, it'll rev to 3000rpm with 1mm accelerator pedal depression. It gives the impression the engine has better throttle response but realistically, it does nothing performance wise. Cracking the throttle with throttle controller feels a bit like running an automatic off the drive plate with the box and converter out, light flywheel effect.
BMW M cars change the throttle sensitivity and pedal ratio in sports mode and if you hold constant throttle at 80kmph and hit sports+, the car will accelerate to 90kmph, so it opens the butterfly more without pedal depression.
SV6's are bit lazy on the throttle where you need to stand on it a bit to get them moving. Jump in an FG Falcon that has a sensitive throttle and press it like an SV6, you'll light it up just about! The V8 throttle sensitivity feels good, but an SV6 would likely feel sharper with a throttle controller.
My BMW also jumps when I hit the sports mode button while in motion, do you also notice how the accelerator pedal becomes instantly firm under your foot, it requires more effort to press?
At the same time the steering response through the steering wheel also becomes firm in your hands.
You can physically feel the characteristics of the car change.
Still none of it is over sensitive, it still has a nice progressive feel.
