Thump in drivetrain at low speed
chucky083
VY Calais V8
I have a V8 VY Calais. 4sp Auto.
At very low speeds just as i accelerate from standing or if im coasting in heavy traffic i get a thump that feels like its between gearbox and diff. It seems to be irregular (not in time with engine/gearbox speed) and never occurs above ~10km/h. It happens in both drive and reverse.
Has anyone else experienced this?
Is there any likely suspects to check out?
Or is this just a design flaw with the gearbox being clunky between neutral and drive/reverse?
danja
Swerves for gay koalas
CBF 250 and a Levin ZR
Is it happening just as you step on/off the accelerator?
madgamer2006
VY Executive 2003
this happens on my vy executive as well... any help would be great
DUK13Y
When in doubt, slide it out
Sydney, Australia
www.facebook.com
VEII SSV, VYII Berlina, '97 Lancer
simmyz1
VS III V8 UTE
this sounds like a prob i had with my wagon and it ended up being spark plug leads, believe it or not!, local mech said it was common problem as a faulty lead caused a miss which, to me , sounded like a diff or tranny thump.. hope this helps
red truck
just left of hell
VY one tonner / gen3 / 6speed
If it's a heavy dull thud could be broken engine mount. Mine was doing it from time to time.
Confirmed it by blipping throttle at walking pace, really makes it thump.
Bazzdogs
Sydney, North-Western Suburbs
VT Commodore S
it can just be a general looseness in gears. Getting movement from the motor all the way to the drive wheels requires alot of linkages and gears. between each gear might be maybe a millimetre or two of slack, not much. Add all these gears and slackness together and you got yourself a big gap which needs to be taken up by force from the motor. Thats what i was told, my first gear is so low tuned i can physically get a smooth drive in traffic without disengaging the clutch. if i speed up in first i always get several big jolts cause it almost throws it self forward which puts more slack in the gears.
vt s
vt s s1
Pop your bonnet get someone to stand at side of car while your inside.
Put in drive, hold foot on brake and just quickly and lightly blip the throttle.
This will find if its your engine mounts or something else.
