Thump noise from VS Engine bay
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by someguy360, Jul 12, 2011.
  1. someguy360
    someguy360 Well-Known Member
    Adelaide Hills
    Hi Guys
    My VS has recently developed a thumping noise from the bottom end/rear end of the block.
    It only seems to occur after the engine has been run for around 10 minutes.
    I can feel the thump through the floor/pedals but its only really noticeable when the car is idling, it seems to disappear while I am moving.
    At first I thought it could be caused by my dying harmonic balancer but replaced that today and that made no difference.
    The last oil change I changed the type of oil I have been running to Castrol Edge Sport & some nulon engine flush and before I was running Penrite full mineral oil (the problem started to occur around 800km after the change of oil type)
    Any ideas?
    The engine still goes just as hard and doesn't seem to be idling rough and fuel economy hasn't changed.
  2. pjdm1980
    pjdm1980 Shut up Jr I'm thinkin!
    Geelong, Victoria
    E1 GTS BUILD NO# 007, GQ Patrol.
    Maybe throw it up on a hoist and let it idle see if you get a beter look at were it's coming from?
  3. someguy360
    Adelaide Hills
    I have had it up on ramps and have gone over most of the undercarriage of the car and can't seem to pin point it.
  4. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    Sounds like a part of the engine hitting the body....maybe due to a sagged/broken engine mount. If the engine is high mileage (300K+) then maybe it is the balance shaft.
    Edit....when engine mounts sag badly and the rubber is gone, then mount then is metal to metal with a solid thump thump thump.
  5. someguy360
    Adelaide Hills
    Turns out the engine is disintegrating :(
    Did an oil change today and down the bottom of the oil pan was lots of little metal flakes :(
    Sigh, new engine time it looks :(
  6. cander24
    cander24 New Member
    NSW South Coast
    VZ GTO. VS LS1.
    Bugger! Sounds like shes spun a bearing.
