bnghardy
- Feb 26, 2010
- 36
- 0
- 6
- Location
- south/ eastern qld
- 2001 v6 vu ute
Need some info??
My ride is a vxii 6cly auto. when I reverse out of the drive way or car park the car vibrates (grinding noise) to a thumping noise from the rear end only
very lightly or not real loud and only when it's going in reverse. could it be the rubber uni joint (yoke)on the tail shaft.
but before you answer it went to Sydney last week from Brisbane there was shuddering ( misfiring) every time I accelerated to over take or to go up hills. when I got to Sydney looked at the spark plug leads and found one was corroded at the coil pac so replace them and it fixed that problem. So what I'm getting at would all the misfiring cause the rubber (yoke) uni to weaken up the rubber to cause this thumping and grinding at the rear end when reversing. and can I check it like you do a normal uni joint. or is it my rear brakes need changing
any ideas welcomed.
any ideas welcomed.
