TICKING NOISE, NOT SURE IF LIFTER
samlicastro94
perth
VY S2 Clubsport R8
Hey guy's,
Have a ticking noise that increases with the rev of the engine. The tick doesn't start forming til the car warm's up and doesn't sound like it's coming from the top of the engine.
It sound's like it's coming from a header gasket leak maybe or noisy extractors.
The sound is extra noticeable from below the car. I have jacked it up and couldn't find any sign of an exhaust leak however I haven't been under it when it's been started.
All the header bolt's are tight is there a way to definitely determine the source of the noise whether it may be a lifter or exhaust leak.
Sound's far fetched but could it even be a tick from one of the spark plug lead's earthing out? (They're 10,000km old lead's and so are the spark plugs)
Thanks!
PlenumBiscuit
VY Commodore
swap some leads around from 1 to the other if u feel its that, are your sparks in tight? do u have any old sparks laying around, maybe a spark is up **** creek
can u take the belt off and start the engine for a bit (after youve warmed it up) see if noise still exists
not likely but maybe a vaccumm hose leaking
is the oil full, maybe errors arent showing up on dash, and needs more oil
samlicastro94
perth
VY S2 Clubsport R8
Turned out to be a spark plug was not even half a turn loose. Maybe the noise was it arcing out on the cylinder head or something?
Thanks for the suggestion
PlenumBiscuit
VY Commodore
Great news mate
An unsealed chamber i guess when fuel explodes then noise came out the loose spark
