ticking noise
Discussion in 'VY Holden Commodore (2002 - 2004)' started by macka_21, Sep 7, 2011.
  1. macka_21
    macka_21 New Member
    Whyalla S.A
    V.Y SS Commodore 5.7 6 speed manual Cammed
    hey all
    i got a vy ss with a cam and i have a ticking noise when its warmed up but its not constant just every now and again.
    any suggestions wat it could be?
  2. bogan_vk
    bogan_vk New Member
    australia
    commodore
    lifters possibly.
  3. cander24
    cander24 New Member
    NSW South Coast
    VZ GTO. VS LS1.
    As above. Good chance its your lifters. This is often worsened with an aftermarked cam if it has an agressive profile. What type and grade of oil are you running? Running a different reputable brand or grade can often help this since its only intermittent.
  4. macka_21
    macka_21 New Member
    Whyalla S.A
    im running 5w 30 full synthetic
  5. macka_21
    macka_21 New Member
    Whyalla S.A
    i had a look under the car and noticed that i stock cat converters on it could it possibly be this?
  6. macka_21
    macka_21 New Member
    Whyalla S.A
    well i thought i would make a update the noise is still there and its getting worse, i put this free up noisy tapet/lifter and it hasnt helped so i dunno wat i could be.
    would a diagnostic computer find a fault or?
  7. DevilDRake
    DevilDRake Braaaap
    Skye
    2006 VZ SS 6L Ute
    My cars got a tick in the far left cylinder aswell haha. I suspected a lifter aswell, even though i got all of mine replaced with the cam install.
    Check your oil pressures hot/cold in conjunction with the Holden specs
    Check your oils etc.
    If that's all good, (this is sourced from Steve @ Mace), he said you can cheat by putting a higher ratio rockers on as they put more force onto the lifter, which (in short description) stops the ticking.
    ^ I'm not too sure on that stuff though, you're better off asking Steve about that - So don't take my word on it.
    I know this might sound weird, but it could be your injectors too.
    edit: How many K's has your car done? If it's over 100,000 I thought running higher than 5/30 was more recommended. I ran a lighter oil in mine by accident, and it definitely made a loud ticking noise from the injectors. - Which got louder.
  8. MACE
    MACE Well-Known Member
    Just to elaborate on what DevilDRake's mentioned, you can also linish down the rocker pedestals or run slightly longer pushrods. This will put more lifter crush on the lifter, often curing a lazy lifter. I suppose it might be something to consider prior to changing lifters
    Cheers,
    Steve
  9. Macka21
    Macka21 New Member
    Whyalla S.A
    CAMMED VY SS Series 2 M6
    My car has only got 95xxx on it
  10. Yamaha Techy
    Yamaha Techy New Member
    S.A
    VZ SSZ Ute
    my ute does this i reckon its the hydraulic lifters it goes away after the oil pressure bulids up well 4 me anyway
  11. oska
    oska Active Member
    vx custom 600RR
    it's the PVC
    i bet it only happens when the engine is slowing down
    if it were an engine problem you'd hear it all the time
  12. MACE
    Ah a cam, then you may need longer pushrods depending on the cam base circle (reduction in size)
  13. Macka21
    Macka21 New Member
    Whyalla S.A
    It only happens when it is idle
  14. DevilDRake
    DevilDRake Braaaap
    Skye
    2006 VZ SS 6L Ute
    Haha like mine, i hear it.. all the time.. With music and everything down obviously.
  15. Macka21
    Macka21 New Member
    Whyalla S.A
    Yeah man thats wen u hear it bloody annoying
  16. macka_21
    macka_21 New Member
    Whyalla S.A
    well another update and its worse then i thought i is a broken valve spring and also while i was in the engine bay with my mechanic there was a another diagnosis... my water pump is on the way out.
    so i shall be calling the delaership i bought the car from and see if they are gonna fix the problems. i will keep updating on progression
  17. macka_21
    macka_21 New Member
    Whyalla S.A
    well today the guy from the car dealership and he isnt going to pay for the valve spring replacement, but he will replace the water pump.
    i wasnt happy with the outcome so i had a heated conversation with him and after all of him spinning some crap i got a outcome of him putting $200 towards the new performance springs
