Time to take the engine apart. Any suggestions?
Discussion in 'General' started by stocky, Sep 10, 2007.
  1. stocky
    stocky New Member
    Well I'm considering take the engine apart a bit over the next couple of weeks. I just got some heavy duty valve springs and I'm going to replace the lifters to stop my engine from ticking. Is there anything else I could do to the engine while its in pieces. Ive heard of people suggesting timing chain with the valve springs, and Im thinking some gaskets to try fix some rev hunting at idle. any suggestions on what else i could do would be great
  2. Joey_21
    Joey_21 New Member
    Western Suburbs
    VY SV8 HBD---mmmm LS1
    so thats what the noise is in the lifters my engine ticks didnt no what it was can they cause any damage like this or jus worn out?
  3. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    If you are going heavier springs I would put on a double row timing chain or you might end up with the same problem as paradox, broke a tensioner. Apparently a lot of the US guys are breaking tensioners too when going heavier valve springs.
  4. stocky
    stocky New Member
    hmm what would one of those set me back?
  5. Reaper
    Timing chain, camshaft (with a little more poke).
    Reaper
  6. Pub247
    Pub247 Well-Known Member
    Melbourne S.E.
    Ford Fairmont
    Timing chains aren't that expensive depends who you know and where you buy them from. Never priced one for a v6 but i can get v8's for around $100 mark. If you got the timing cover off you might as well put in a cam, something to suit the charger if your keeping it. New water pump since you'll be pulling it off anyway. Are you going to take the heads off or just do the springs while they're still on the motor?
    The gasket that would cause idle hunt are more than likely manifold and since thats coming off they're going to be changed anyway.
    I suggest you get some decent lifters as cheapo ones won't last long with a new cam. A month before one went in my vh with a crow cam.
    Thats all off the top of my head maybe some other people can offer some more advice.
  7. Krustyone
    Krustyone Member
    2016 VFII SSV Redline
    A ticking noise under bonnet means a lifter is dry or running low pressure.
    Lifters are hydrolic and work under oil pressure when the engine is running. These lifters have a hole approximately 2- 3 mm wide which allows the pressurised oil to fill the lifters. If this hole fills with crappy oil or deposits from the walls of your inner engine, the lifters are not able to be filled with oil and you get a slack between the lifter, push rod and rockers.
    It is asvisable never to use an internal engine cleaner as this removes the sediment from the inner wall of teh engine and can block these lifters if not other crucial parts of your engines oil veins.
  8. Joey_21
    Joey_21 New Member
    Western Suburbs
    anyway 2 clean it and do they cause power loss or shudnt i worry bout it been doin it 4 over yr so im not 2 worried
  9. Reaper
    No power loss and as you have noticed - they can go on like that for years. A great excuse to get a new cam IMHO.
    Reaper
