timing chain kit, yay or noooo? lol
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by jas98, May 6, 2012.
  1. jas98
    jas98 Active Member
    maryborough QLD
    vs commodore V6 S2 and a BA XR6T
    eBay Australia: Buy new & used fashion, electronics & home d
    has anyone used this and is it a good one? i know its a factory type chain
    also would a roll master one be better? any benifits? power or life?
    gonna take the timing cover off and sus out me front balance shaft bearing as its making slight noise that i hate!! but yeh while im at it im thinking ai may aswell do this as on me old vn i changed the chain for good measures and god it went good after that, but that had over 300 000 on teh clock my vs has almost 170 000
    cheers
  2. UW1SH
    UW1SH New Member
    For that price i would get it anyway… Altho could be a case of cheap **** aint good and good **** aint cheap
  3. strgas
    strgas GRA = REAL HP
    good enough for a every day driver thats stock , roll master would be over kill unless you wish to have an adjustable timing set .
  4. Chrispy
    Chrispy Member
    VZ Calais, 2015 Daytona 675R
    Personally for me, I'd be spending the few extra dollars on a good quality rollmaster set. Never go with cheap **** for engine internals
  5. RX25SE
    RX25SE Real cars are steel cars.
    MY07 Liberty 30R Spec B 6sp wagon
    Have you priced genuine?
    On occasion I have found genuine parts at a similar, or even cheaper, price than aftermarket.
    The kit it self will not give any more power.
    The advantage of something like a Roll Master is to be able to rotate the cam accurately and reliably at high engine speed with the added load of stiffer valve springs plus the ability to set the cam (after-market) timing to the desired specs.
  6. James39
    James39 Gave up on VL's
    Newcastle NSW
    1995 VS Acclaim & 1992 Holden Barina
    How easy is the chain to replace? I am thinking of changing mine since mine has many k's on it.
  7. RX25SE
    Front of the engine needs to come off.
  8. jas98
    jas98 Active Member
    maryborough QLD
    well i won a roll master kit for it on ebay for 50 bucks brand new, think its one that is single keyway, not the multi keyway ones, i figure it will cost basically the same as that kit with getting the dampener (maybe 20 bucks extra) and its a better quality kit
  9. James39
    Newcastle NSW
    Indeed, but I just wanted to know how hard it is to replace :)
  10. jas98
    jas98 Active Member
    maryborough QLD
    lol i priced it for a vn from holden a couple years ago and got as far as the sales guy saying "the chain is $325 and the sprokets are....." at that point i said dont worry lol even he thorght #### me thats dear haha
  11. jas98
    jas98 Active Member
    maryborough QLD
    it all depends how much you like working on cars, to me its not hard at all, bit time consuming though, i redon the whole top end (head gasket etc and clean ) of me mates vs in about 9 hours, #### me my back hurt after that haha car still runs like a dream somehow as it was basically the first time i done it...well second as i did it to a vt but it was already in pices when i brought it and i did it over 3 days lol
    as for the front of the engin, id rather do that then the top end....trust me! you just gotta make sure you line up the timing marks correctly, even if you double check after you double check as you dont want that ####ing up at all
