4bait
- Sep 24, 2005
- 48
- 0
- 6
- Age
- 59
- Location
- Cheltenham Vic
- VR
I Have an Ecotec in a boat with several broken valve springs due to the engine revs fairly hard for long periods etc, it's not the first time the standard springs have broken, this time the broken valve dropped in and it has destroyed the engine at only 10 hours old, so lesson learnt and I will be upgrading the springs etc with a new engine build.
The Mace site says that with upgraded springs I also need a double row roller timing chain and in order to fit this the ballance shaft needs to be removed and oil hole plugged.
Is this correct? and will any adverse vibrations etc be noticed or other problems with the ballance shaft removed or will the engine need to be internally ballanced to suit?
Also it says that no tensioner is used on this timing chain so also wondering about chain back lash.
The rest of the engine and cam etc are fairly standard at the moment
Cheers Andy
Cheers Andy
