timing cover. do they have water jackets?
defa
VN Commodore
on the front of the timing cover on a series 1 motor. there is a place there that is flat. and has a bolt hole there. it looks like it is there for some sort of fitting that australia didn't need. if i drill into it to put my oil dump there. am i going to find a water jacket?? does anyone know. i would be thinking no. but i have never had one of these motors apart so i don't know for sure.
Doctor Bob
Grandpa
Retired
RG. Colorado & Caravan
could be where the cam position sensor goes on the later models?
got a pic?
defa
VN Commodore
here is a pic. it is the flat bit with one hole..
Doctor Bob
Grandpa
Retired
yep its the mounting pad for the cam sensor, you can drop oil back in there, but theres not a heap of clearence behind it though.
depends on what sort of fitting you use
Rob
defa
VN Commodore
i had thought about a screw in fitting. then i thought of maybe using that bolt hole to my advantage. i might put another bolt hole in there bolt a flange to it. i don't know if one bolt hole would seal it enough..
thanks for your help on that doctor bob..
AlpineRaven
44
yeah its an cam sensor for Bosch computers 3.8 litre, not needed for delco computers. Thats from behind of my memory - could be wrong.
