Tips on improving fuel economy?
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Maxxiz, Mar 2, 2010.
  1. nathanVY
    nathanVY such boost
    Geelong, VIC
    2003 VY LS1 Turbo Calais, 2005 4Gen Liberty Wagon
    the injectors on ebay I posted before have this part number: 0280 150 960
    how do I find out what the stock ones are. should I put my old injectors back in?
  2. nathanVY
    nathanVY such boost
    Geelong, VIC
    Put my old injectors back in, now its missing.
    I guess ill get a reco set and hope what youve been saying is true and I get better fuel economy.
  3. delcowizzid
    delcowizzid on holiday
    NZ
    в∞ѕтεכ √&
    did you reset the ecu after putting them in
  4. nathanVY
    nathanVY such boost
    Geelong, VIC
  5. benno9911
    benno9911 Donating Member
    Warrnambool
    03 VY S2 Exec
    all i know about my fuel is that my computer says i am using 15.1L of fuel per 100km witch is not to bad i am guessing for around town
  6. The1
    The1 A Memcal a Day Keeps..
    QLD
    VS V6 Berlina Auto
    i bought a spare injector set off ebay, i keep the spare set cleaned and ready to go in a sealed bag, i put oil on the orings to keep them fresh and seal properly when mounted, every 50,000km or so i swap them out for the other set then take the other set back to the injector place to have them cleaned, new orings and filter baskets then flow tested, costs me about $80. When i swap the injectors over i put a new fuel filter on at the same time.
  7. Vsfan95
    Vsfan95 Vsfan95
    VT Series 2 Acclaim
    ave you tried efi cleaner from supercheap or autobarn ( only $2) it tends to help alot for the time being. all you ave 2 do is ave 50 litres of fuel in your tank and you put in 50 ml of this stuff and it does the trick for the time being
  8. nathanVY
    nathanVY such boost
    Geelong, VIC
    ORIXVywags - my cars at 230 XXX kms, what major service components should I do to it, that will improve fuel economy?
  9. Weapon
    Weapon New Member
    SA - South
    Manual VS
    i used to get around 9L per 100km in my vs manual.
    get 11L per 100km in my manual 3L soarer, can go up to 22L per 100km easily by just driving slightly harder....
    moral of the story - drive it like a grandma and your car and hip pocket will thank you :)
    if u can smell petrol alot from the exhaust when just idleing then o2 sensors would be your best bet,
