Tones
Donating Member
- Jan 8, 2012
- 199
- 0
- 16
- Age
- 50
- Location
- SA
- VX SS SERIES2
Rear Shocks and Springs.
When I bought the car, it was set up for towing.
It had FE2 Springs and Monroe Gas Air adjustable shocks.
After doing some research on them, they apparently put a lot of stress on the shock mounts because the spring themselves aren't doing the work or load they were designed for.
Not to mention having the car look like the ass is up in the air.
Because I often Tow quite a few Tonne of firewood a year, I still needed something to help out, and to make sure I didn't scrub. I found these on eBay. SL King springs for the desired height with helper air bags inserted. Operating bag pressure between 5 psi (no towing or heavy passengers) and 30 psi (a trailer full of wood) and a very stiff rear end.
It was a little more involved fitting these, you have to cut a little off of the bottom of the spring seats and from memory I think the top (for the air line). But the result was well worth it.
Much better ride height.
Before -
And after -
Before -
And after -
