Too Hot To Handle...
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by mrhotdog, Dec 4, 2008.
  1. mrhotdog
    mrhotdog What Would Jesus Do?.....
    Adelaide, South Australia
    2003 VY S1 Acclaim
    hey all
    ever since i did my coolant flush about a few weeks ago, temp doesnt want to stay down, yes i used the correct ratio of concentrate:water. it didnt take as much as i thought when i did it though. thermo fan doesnt come on at 3/4 anymore either, i left it idling to see how high it would go but ended up throwin air con on over 3/4. no visable leaks but overflow and/or rad level doesnt stay constant level for long.
    im thinkin either temp gague sender - hard to replace?
    coolant temp sensor?
    any help appreciated..
  2. st3r3otyp3
    st3r3otyp3 Donating Member
    WA bruz
    VX HSV VX SS
    Air trapped in the system? thermostat not opening?
  3. mrhotdog
    2003 VY S1 Acclaim
    for a few days after i flushed it i checked level, bled from screw until coolant comes out. then bled again when warm after driving. seem to go away, now somehow air has returned so i bled it this afternoon. somehow air keeps gettin in there, can hear gurgling noise from behind dash. thermostat was replaced in june by mech
  4. andyman
    andyman The Only 6sp VZ Wagon
    Orange, NSW
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    was the heater tap opened up to max hot when you bleed and flushed it? sounds like it may be your problem
  5. mrhotdog
    2003 VY S1 Acclaim
    yes it was, today i forgot to do it though. but how is air going back in and my coolant dropping? ive had the head gasket and timimg cover gasket replaced within the last 6 months..
  6. 6 shooter
    6 shooter New Member
    West Auckland NZ
    3.8 VR Executive S2/ Kawasaki zxr250
    Did you get the heads retorqued after about 1000ks? because the new head gasket compresses after a while and could possibly leak again.
    Or you could check the heater tap just run your fingers near where the pipes go in and see if theres coolant coming out because there common to crap out because of the plastic
  7. Cheap6
    Cheap6 New Member
    VP Exec
    This has been an ongoing problem for some time hasn't it?
    How are you checking the level, with the dipstick in the surge tank or are you lifting the radiator cap? If you are undoing the radiator cap you will let a little bit of air into the system each time.
    Otherwise, if it is bled properly, it has to be leaking somewhere.
    Apart from the obvious - hoses, water pump, radiator and radiator cap - you might try:
    Looking for leaking welch plugs, but that's not usually a problem in VS. There should be one at each end of the cyl. heads, two each side of the block and there might be one or two at the back of the block, if they're not covered by the rear main oil seal housing. (I think that the rear main oil seal housing gasket also seals coolant but it's been a while since I've looked at one.)
    The knock sensors, one on each side, may screw into the water jacket.
    You might try some paper under the car to catch the water out of the A/C drain to see if the heater core is leaking coolant to there.
    A small leak may dry so you are looking for light brown stains with a powdery residue.
  8. mrhotdog
    2003 VY S1 Acclaim
    Mechanic didnt mention retorquing or anything. like i said no visable signs of leakage from hoses, heater tap
    yes my coolant problem has been ongoing to some extent, but i thought i had fixed it. surge tank level only stays high for a day or two max so i check level from cap when cold, usually have to add a little bit. i normally cold bleed after this. no visable signs of leakage, but since flush like i said the temp has been going up faster when running on LPG. im puttin it in for new bushes in a few weeks so ill get them to check then, but im at my wits end with this stupid problem....
  9. Cheap6
    Cheap6 New Member
    VP Exec
    Sometimes the LPG converter can be located in such a way as to make bleeding difficult. That's another potential leak point too.
    At the risk of asking the obvious again, when you bleed the system is the level of coolant at the filler lifted higher than the bleed screw with a funnel?
  10. mrhotdog
    2003 VY S1 Acclaim
    i guess so, i fill up then cold bleed, go for drive then bleed when i come back, ive been bleeding with engine off but im sure thats what ur supposed to do. where its going is still a mystery
  11. stocky
    stocky New Member
    damn, i saw the thread title and thought it was about me.
    also, no you dont bleed while the engines off, do it while its on. just leave the car running with the radiator cap off, but you should also put an upside down milk/juice container over it with more water in it. seal up the bottle top with electrical tape or something to make a better seal with the radiator cap hole
  12. VS_Pete
    Mods we need a sticky on bleeding air out.
    I keep seeing members with problems with air in system.
    And have put my two cents worth in other posts.
    We could call it How To Bleed A Coolant System. LOL
