too much juice!!
Schitzo06
Tasmania
VR SS S2
Hey ppls just wondering what sort of kms I should be getting from my VR SS Auto. I only get roughly about 280kms a tank on premium around the city, is that about standard? The car is stock, exhaust and all.
betts
vxc
b
Hey mate thats pretty bad, you should be getting around 350kms or up from a full tank, check your ignition system, spark plugs, leads, etc. I know theres other things to check as well but im not sure what they are, a good service might help.
kniever
40
greensy, melb
VY II Calais L67 & VN II Calais T5 5ltr
if you havent already done it go thru and replace ya leads, plugs, dizzy cap & rotor button, air filter, and fuel filter.
those are usually the biggest affectors of fuel usage and are not very expensive but if it hasnt helped much after that i would say your injectors are next
HDT_aero
Banned
SA
manual VN aero
apart from whats been said the oxygen sensor could be the cause
greenfoam
102
VP Executive R-spec
Or the mostly likely failure on the V8s is the fuel regulator
INDACLUB
Black VX SS
37
Black VX SS, White VQ 5ltr
I get 340km to a tank in my vs 5lt and it has a bigger cam in it. I use BP Ultimate.
5ltr-ute
vs serieslll ute
420/430 km`s per 64 ltr tank in my ute. 4.11 & auto
VS series 3
Morton
For external use only
Fairstar the Funship
Shouldn't you be able to get 500-600km out of a long-range tank?
greenfoam
102
VP Executive R-spec
Not so easy for these guys Mortus, most people weigh 50 kilos more than us. That makes for some heavy feet
Schitzo06
Tasmania
VR SS S2
ok now I'm gonna start a major service next week what should I replace first as money is not easy to come by at the moment
