EYY
- Mar 6, 2011
- 5,754
- 2,036
- 113
- Location
- Vic
- VS Statesman
Yep he’s happy to chat - good pr for sure. I spent over an hour on the phone to him not too long ago - and I was just after some info on a manifold I bought. Gives some good insight as to the development and history of his head and manifold design vs those of other companies.
Seems the biggest advantage is added rigidity because the rocker mounting ‘rail’ is effectively a bar that goes from the front to rear of the head all the way along, whereas competitors have split pedestals - essentially in pairs. The oil drain backs have been properly designed for the tp heads too.
I think the biggest advantage of alloy heads is their ability to disperse heat and deal with higher compression without risk of preignition.
However, as immortality said, the money is better spent elsewhere if it isn’t an all out build where you’re chasing every last bit of power.
