torque vs hp
Cava454
35
Box
VR SS, VZ SS
Different modifications create differences in power output. It's most likely they have a bigger cam than you and that's why they have more KW's.
Lol bigger cam... Make me laugh
For shits and giggles ill make more power then u on the dyno with a cam much much much smaller then yours and ill spank you on the street. That setup you have is insanely wrong.
Munz
Right Foot Action
Brisbane NTH
VZ Calais LS1 / VL RB30e daily
212 kw from mafless, than pretty much done everything cuz the motor killed bearings rods and pistons
First thing I'm gonna say its the dyno your getting your work done on, it seems it pulls low numbers but thats no issue the numbers you need to look at are the from the moment you went mafless (212rwkw) to the cam (269rwkw) thats 57rwkw from doing the cam. I think thats pretty damn good.
As the cam is big, PTV would have been close - have you got valve reliefs in the pistons?
Whats been done to the heads? And how far are you spinning the motor?
TI3VOM
Here there and everywhere.
VT Commodore
dafuq am i reading?
Calm down fellas.
I was under the impression that a bigger cam will increase the power your car has (higher up in the revs, being a big cam) thus giving a higher KW figure.
I know this is obviously not the only thing that will give the end result, but it could explain why some people are making more KW's than him, yet he has more torque.
So which one of you two want to actually help answer his question? I seem to be the only person that has had a go at giving him a reason behind why his car makes less KW's but more torque than other peoples.
ari666
250,000 hits
866 nm of torque and 269 kw:
are both useless numbers without RPM. without knowing the variables everyone is just guessing. and if i had to guess, my guess is his stick is too big for his engine and it wont rev. thus a good low rpm power, and balls revs.
edit* but i am just guessing :p
Cava454
35
Box
VR SS, VZ SS
Big stick = plenty top end and not as much downlow.
Dyno figures are just that. Wank talk you have between mates.
Big-Al
Banned
Aussie and proud
VY SS 5.7 M6
well you're making more torque than an LS1 with a blower so you shouldn't complain too much
Immortality
Staff member
Sth Auck, NZ
Dyno's measure torque at the rear wheels which is a LOT different to torque at the flywheel. Things like transmission ratio's and diff gears multiply torque, even things like wheel diameters/tyre pressurs and types of oil used can influence dyno results (as well as how the vehicle is trapped down on the dyno).
Engines produce torque, HP is a purely mathematical equation or HP = torque x rpm/5252
samnon
35
sunshine coast
vt ss
thats the dyno for it, i'm not chasing massive power for it, i'm happy enough with how it goes was just wondering about the torque, it seems pretty high for a ls1.
samnon
35
sunshine coast
vt ss
its been on dyno fair few times for retunes when i've changed stuff, there forged mahle pistons with valve reliefs the heads are ported with bigger valves its gotta ls2 intake with92mm throttle body. its peaking power around 6400
