Any resolution? Brother in law having same trouble.
Hi, not yet.
Replaced ignition switch, and ignition barrel (as I broke barrel playing with it).
Still cutout, So took to a mechanic today for Scan Tool check.
Few fault codes came up, so they reset and car Cutout again.
New fault codes are
- Engine control ignition relays
- EEPROM check sum error
-No serial data BCM
Mechanic cleaned earth points and swapped out ignition control relay and main relay.
Car STILL cut out GRRRR
Also said charge system very low/not charging and suggested to replace alternator before investigating further.
BUT battery doesn't run flat, so not sure if this would cause car to cut out? does anybody know if this would cause this?
Going to try tapping alternator to see if brushes maybe stuck?, temporary fix I know, but if it is that at least I will know before replacing it.
Will keep posting progress
