tps fault
king_rick
adelaide
VT 5.0L Berlina wagon
took the throttle body off to clean the IAC yesterday, put back on drove fine last night. today im getting a fault code for the tps, wont change into gears properly.
Took it off again looks fine was thinking I maybe got a bit of carby cleaner in it... could this be my problem? Or what else might it be, thanks.
BlackVXGTS
Melbourne, SE
Did you remove the TPS at all?
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
if you sprayed cleaner on the butterfly and its run down the shaft into the tps it will be cactus
king_rick
adelaide
Bugger it's obv fkd then cheers guys, they're only $58 from sprints I'll just replace it.
king_rick
adelaide
New TPS and same fault, do I need to reset the TPS or some ****? And if so how?
king_rick
adelaide
WTF LOL forget it I gave up then decided to switch the old one back in... no fault code, runs like usain bolt! I noticed the old one san anti clockwise to be fitted and the new one span clockwise and couldn't be reversed, I'd keep it as a spare but it's obv the wrong part.
