Shar3e
My 2014 vf ss is going back into the gearbox shop today. Been doing a bit of reading up on the penrite pro gear 70w-75. Has anyone changed there's over to this, is it worth doing?
Bit of background, I had a bearing noise when car was in neutral, as soon as id push the clutch in the noise would go away, had 3 different mechanics tell me it was a throw out bearing, I still had the stick clutch in so while I had the box out I upgraded the clutch to a exedy heavy duty, and converted to a solid fly wheel. Of course I got it back and the bearing noise was still there. Done a bit of my own research, come to find the noise is more likely to be a input shaft bearing as throw out bearings only make noise when the clutch is pushed in not out. Took it to a box shop, the guy had a listen took it for a drive said it was definitely a bearing in the box, quoted me 1300-1800 for a complete bearing kit with me having the box pulled out and delivered to him. He called me and said he got away with doing a minor bearing kit? 3 bearings were replaced. I paid 1300. Got the box put back in.. bearing noise still there, now it won't go into 4th gear properly and pops out. I've called him back up, told him about 4th gear, he said I can take it back in and he will fix it, when I told him the bearin noise was still there, he is now saying it is most likely gear noise? It does not make the noise in gear.. Only neutral and disappears with clutch in. I'm fuming. I've now spent 2 and a half grand on a new clutch and a further 1300 on box work for the noise to still be there, a long with days at a time without a car . Going in this arvo to drop it off and have a talk. Just wondering if I should drop off the penrite oil for him to put that back in? Any advice or what not. Thankss
