VTSS350 said:
No It slows the wheel speed down, thus allowing it to gain traction again.
Two fold, it transfers the power to the side that does have traction, and brings the wheel speed closer to the road speed...
No it actually applies the breaks aswell. It breaks the wheel that has lost traction.
But no it doesnt wear out your breaks .
How does that work? Obviously if its applying the breaks then its going to wear them...
Also depends on the vehicle as to the level of force exerted when traction is lost, the AWD's apply alot more brake to get out of sticky situations, and tend to overheat the system fairly quickly... Doing reconaisance for the QLD round of the Australian Rally Championship we had the traction control turn off twice because the abs pump overheated the fluid...
Same story on the beach, the traction controlled AWD's are brilliant on the beach until they turn off and then you have a two tonne, 3 open diffed commodore spinning diagonally apposed wheels! Been there done that! :ranting:
I wouldn't be worried about brake wear, seriously, a full set of good pads are only $65 and performance pads are only $100... :whistling Its not even worth worrying about...
In 25,000k's i've gone through two sets of front brake pads, and am just about to change the rears... Mind you i regulary tow two tonne of rally car and trailer, spend copious amounts of time with the traction control going nuts, and do tarmac rallying in it... What it cost me? About $75!
