trailer lights
Hepster
vf calais
Hi guys
My indicator lights have stopped working on my trailer.
Replaced the old globe indicators with nicer led version.
tested the voltages coming out of the car plug, both tail and stop lights get voltage but nothing on the indicators. Is there a fuse blown somewhere?
I have never had a problem before with the indicators in the 6 years I've had the trailer
Any help welcome
Cheers Graeme
gohrdrgomad
Australia
VxCaly57
Hi guys
Any help welcome
Cheers Graeme
are the vehicle blinkers functional and the trailer socket pins non functional?or all non functional on the car
1985VK
Australia
VK SL
Check you have voltage at the pins in the socket on the car. Then check for continuity and voltage at the lights on the trailer. Make sure your earth is good on car and trailer.
losh1971
North Tas
VE Series I SS Ute
Try bending the pins on the traier plug out a bit, ie open up the split a bit wider. After a while they can close up and not make contact.
Hepster
vf calais
yes, the car blinkers are working fine just the trailer plug output not seeing any voltage on it
gohrdrgomad
Australia
VxCaly57
that harness goes to your tail light loom from memory. Maybee a broken wire in the back of the socket. It does happen.
