Trans Fluid
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Greggles_VS, Aug 30, 2012.
  1. Greggles_VS
    Greggles_VS The Noob
    VS Acclaim V6 Ecotec
    I found i have a leak around my trans sump and picked up the trans service kit, going to get the fluid tomorrow, which brands have you used and would you recommend along with what brands youve found troublesome. Cheers
  2. Jxfwsf
    Jxfwsf Well-Known Member
    Aus
    commodore
    I've used valvoline DX-III for many years (try to pick it up on special and have a bottle or 2 sitting aside in advance)
    I'd never use any cheaper shop branded stuff (even though it's usually bottled by a larger well known company, it's cheaper for a reason)
    Any decent brand name fluid should be good quality, valvoline, penrite etc etc, have you tried nipping the pan bolts up a little tighter to see if the leak stops?
  3. Greggles_VS
    Nah i didnt want to over torque them, figured its had no service history for over 100,000kms, so best to just replace it and know its gonna last me, plus i bought a torque gauge so i can tighten them to spec
  4. Trikky
    Trikky Member
    Central Coast
    VF S2 SV6 Manual
    personally I would just go for AC Delco DexronIV but any good brand of Dexron III or Dexron IV will be ok
  5. Greggles_VS
    Ended up with a great deal, got 2 4L bottles of valvolene atf type f for $34 cos bottles were damaged
  6. Trikky
    Trikky Member
    Central Coast
    VF S2 SV6 Manual
    I personally would not use that oil as it is specifically for ford not gm auto's
    I paid $39 for 4L of AC Delco DEXRON III fluid the other day from my local bullseye
  7. Jxfwsf
    Aus
    commodore
    was thinking the same as trikky in regards to using type f but from a quick look at some older us gm forums it isn't uncommon, probably not advisable to put in a new trans under warranty but an older worn trans apparently the different friction materials in the fluid can be a bonus..... might give it a go in the 4l60e/th700 bitsa leftovers box i have here if i ever get it back in a vehicle lol
  8. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
  9. VYMAD
    VYMAD SILVERFOX
    BUNDABERG Q
    VY EXECUTIVE S2
    Dexron III only, don't use type F or
    anything other than Dex.
  10. showbags
    showbags SENIOR EL'BAGO
    VT Calais, BMW 135 m sport
    Type F is a courser fluid than DEX III. It will kill you trans very quickly.
