transmission code 6.8
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Zuicider, Feb 3, 2009.
  1. Zuicider
    Zuicider Banned
    Stonedville
    Set of thongs
    Code 68 - Transmission Component Slipping - Auto Transmission Only
    can that be fixed with a solinoid change or does that mean my clutches inside are rooted and nothing is going to be able to fix it. im getting good 1st and 2nd but no 3rd or 4th as it just high revs
  2. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    Solenoids will show a code 81 or 82 from memory. If there is still a bit of forward motion in 3rd/4th then maybe a can of 'trans stop slip' might help - it makes worn clutches grip better but cannot work miracles. I've noticed SuperCheap have a new range of Lucas products in cans to fix everything (if you believe what they say on the can). Whatever, $12 is cheaper than a reco (which is inevitable)
  3. Zuicider
    Zuicider Banned
    Stonedville
    Set of thongs
    hehe its all cool gearbox died
