delcowizzid
on holiday
as long as the engines running and its been through the gears to send fluid all round the box and filled the cooler its all good. the pump is pumping out the sump as long as the engine is running so keeps the level down.
ok guys im a trans machanic you can eighter do what they have said have the car in drive and the handbrake on or just check it in nuetrel with the engine running u will still get an accurate enough reading, good luck mate
This thread is a load of crap. Who thought up the "check it in drive idea??"
After motor is hot like, after a twenty minute drive, park on level ground with the motor idling and gear box in PARK. Then take your readings on the dipstick. If you've just done a full box service and have added new fluid then put in nearly the specified amount (4.8 litres or whatever your book says) then start her up in park and check the levels but wait till you've had a reasonable drive around before reading the level too seriously.
I agree with you guys - not sure where the idea that the transmission had to be in drive came from. Holden workshop manual clearly states:yup i always have the car running and transmission in park ive never heard of having to have a commy in drive to check it. it seems silly and dangerous (i know even with everything secure) just doesnt sound right
