deserthead
- Oct 20, 2004
- 1,085
- 76
- 48
- Location
- Cairns QLD
- VS III l67 Column Shift Ute
Bottom is outlet and top is inlet.
I just drop the cooler hose, pump out 4 litres and then put 4 litres into the filler tube, simple enough. I'm not sure if the return line will suck fluid back into the transmission as the cooler line works on the pressure from the inlet side and not the return.
