Transmission Oil
Guys, after some help if possible please!!! Did a real big mistake today in my VF SV6 Holden commodo
  • Help needed
    Votes: 1 50.0%
  • What’s the best way to check and refill
    Votes: 1 50.0%
  • Total voters
Jayden1985
39
VF Sv6 Commodore Sportswagon
Guys, after some help if possible please!!! Did a real big mistake today on my VF SV6 Holden commodore . I emptied my transmission oil instead of engine oil ... absolute idiot just wasn’t thinking , does anyone know how I can refill my transmission oil?
Clay1391
33
Warragul
Ssv redline
Look in manual it should tell you how.
greenacc
Searching for the billion
VE Berlina
Refill it with the same amount of correct grade fluid as you emptied out of it, using the fill plug on the side of transmission.
VCoz
VF2 Calais SW LS3 MY16
I have not changed the oil in this type of transmission as no dipstick to check levels (I understood a GM tool is used)
The site linked before has a number of statements re this task that suggest Jayden seek someone's advice who has done it before and research is done if the replacement fluid is not the specified GMH product.
Some of those statements are copied below:
"The drain and refill procedure is quite involved and very, very explicit in how the procedure is to be performed in order to achieve the proper fill level." "For the A6, look up the procedure first before draining it. Its quite a lot more difficult to drain/fill the auto than the manual. For example, the trans fluid has to be in a very narrow temperature range which isn't cold and isn't full operating temp."
Re greenacc "Maybe, if you assume the initial level is correct and use a syringe with flex tubing through the fill hole to remove and add. Make sure you measure carefully, don't spill any and don't push any dirt into the the trans. You won't change much of it that way though as most of the fluid will be inaccessible.
The "drain" plug on the bottom is to check the level which must be done with the car running and at a certain temperature. The manual specifies dropping the pan to change the fluid. The final level of the fluid is critical to the correct operation of the transmission. The manual trans is far simpler with a drain plug at the low point and a fill plug at the fill level of the trans. The manual is not as sensitive to fill level like the auto and much easier to fill to the correct level."
Again I don't have the answers needed but have personally experienced the problems of your V6 A6 model gearbox having low oil.
Ron Burgundy
NSW
VF II SS
Why on earth would they get rid of dipstick and the ability to check and top up the oil....
wraith
Hand over the dog bikkies
Demonicaland
VX V6 Berlina. 2003 VW Passat
Welcome to the future. It's lifetime oil now (apparently)
greenacc
VE Berlina
So your box slowly starts to play up and you take it to the stealership (of course) to have it looked at, for a fee ;)
Ron Burgundy
NSW
VF II SS
Merc has done it with engine oil now...
Can't check it. No dipstick
monstar
Naturally as-pirated
56
depths of Hays Inlet
facebook.com
Peugeot 207 GTi
Unless there is a catastrophic terminal problem there is no chance of fluid leaking out. So what’s the point in checking fluid level in a closed system?
See the fluid level checking protocol on the 6l80/90 is quite advanced because basically Dexron VI (special ATF) expands its volume with energy (heat) anyway. That’s why even taking your car to local auto trans specialist who does normal slushboxes generally underfills our trans.
In other words like tearing down a PC, it’s not that it can’t be done by anyone but not advisable for most people to make a decision about levels without following the proper procedure. There’s a high chance owner will break it, not fix it.
It does need changing every 80k km - 100k km, or as soon as 1000km if you abuse (cook) it.
Also there were trans dip sticks for our car sold in the US, after 20k - 40k miles water, snow and shit got in through incorrect fitting / refitting, drawing PITA level dipstick up through engine bay past headers.
