Transmission slipping stuck in 3rd or 4th gutless low down
N
nielo
Guest
Every gear feels like its slipping and wont drop back to lower gears under acceleration so I ran a diagnosis test and these are the auto transmission fault codes 66, 67, 81, 82
I checked the gearbox fluid and it seems fine, im guessing if It was only one fault code it may be electronic - but 4 fault codes seems a little fatal - I think it may be easier/cheaper to have a second hand gearbox installed, Holden wants $2200 for a new box.
Thanks Nielo
sircruisealotVS
South Brisbane
VZ LS1 Calais
yeah, i does sound bad...might be worth while at least taking it to a transmission place and seeing if they can shed any light on the problem though, before you get a newie.
Doctor Bob
Grandpa
Retired
RG. Colorado & Caravan
check the fuses, the most common cause for logging all these together is a blown fuse.
Rob
hako
Donating Member
80
Toowoomba SE QLD
VS11 BT1 V6
Sounds like its running in "limp home" mode.
V
vasili vr
Guest
gearbox
hey man i dnt fink its worth gettin a new box... go 2 rekcers or at sum transmition specialists and u can get a reconditioned box for as cheap as couple hundred buks.
dmitch
DonkeySS
39
Perth W.A
VS SS S2
recons box will set u back at least $2000 4L60E or about $1500 for the 4L60 worth goin 2 trans place and c if they can find out wats wrong
Famine
35
VR Berlina V6
Mine did the same and it was the 3-2 solenoid, got it fixed for nothing cause I recently had some work done by the same bloke :D
N
nielo
Guest
Is that solenoid inside the transmission - i mean would the gearbox still need to be removed from the car to replace that solenoid?
Thanks for all the input guys/gals I really appreciate the response's from the community..
