Transmission stopped working - VZ Calais
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by hays1530, Nov 11, 2015.
  1. hays1530
    hays1530 New Member
    2005 VZ Calais
    Hi guys,
    This is my first post as I've just got my hands on a VZ Calais and need some help getting it going. It's a 2005 model 5 Speed model.
    After getting a new battery and getting it turned on and what not, I drove the car for perhaps 500 meters before stopping at a set of lights. After stopping, when I went to kick off again, it wouldn't move - Just reved up. I tried shifting the gearstick down to L but this made no difference. No matter what the car didn't want to go into gear.
    Some history: The previous owner (My cousin) told me the transmission was busted. But he said it happened suddenly. One night it was fine, but the next morning it stopped working. There was no gear slipping for a while first.
    I've tried searching for an answer on the forums, but all other threads are people who've had slipping issues for a some time before the box finally gave up. In this case, it was sudden.
    Note: While it was driving that 500m, it shifted with no issues at all. It was all very smooth and pulled really well. It was only after stopping at the lights that I could get it moving again.
    Any guidance would be much appreciated. Thanks in advance.
    Hays
  2. JoshlikesCalais
    JoshlikesCalais Active Member
    VE SSV Z
    Either your clutch is gone, or an air bubble in the clutch master cylinder. I think
  3. MYVESSV8
    MYVESSV8 Well-Known Member
    Brisbane/GoldCoast
    VE 6LT M6
    if its an auto, how much fluid is in it
  4. hays1530
    hays1530 New Member
    2005 VZ Calais
    I'm not sure. There's no dipstick...from what I understand, it's a 'sealed' transmission so it's supposed to be good for life or something like that...? I'm not sure to be honest.
  5. Benboy
    Benboy Well-Known Member
    Hill River, SA
    2007 SVZ Wagon
    When was it last serviced ?
  6. rambunctious
    rambunctious Well-Known Member
    Mooloolaba
    VZ Wagon
    Is it Manual or Auto,
    I have never seen the letter L on any Gearshift.
  7. hays1530
    hays1530 New Member
    2005 VZ Calais
    It's an auto 5-Speed. P R N D 4 3 L.
    To be honest, I'm not sure when the last time the service was, but it has been sitting around for about 6 months so it's been a while. I can see these autos going second hand for about $1500+. Is there any cheaper fix to this? A reco or service of some sort?
  8. MorganVZ
    MorganVZ Member
    VZ Berlina
    If it's an auto it should have a transmission dipstick (my 4speed auto VZ had one), the manuals are sealed.
  9. Gaiter
    Gaiter Active Member
    VZ SS Thunder
    This is from the VT VX VY VZ service and repair manual
  10. hays1530
    hays1530 New Member
    2005 VZ Calais
    Hmm, so I'm correct in saying there is no dipstick but the level can be checked by jacking the car up and checking the filler plug. I'll do that. But would low fluid explain the issue considering the box is never supposed to run out..?
  11. Gaiter
    VZ SS Thunder
    Now that I can't tell you. Just a DIY'er like you. Good luck
  12. rambunctious
    Mooloolaba
    VZ Wagon
    You said it has been sitting for 6 Months so it may have been leaking.
    Pull the plug, stick your pinky in the hole and point it down.
    If you cannot feel oil then time to start filling it.
    You can get squeeze Oil bottles for Auto Boxes. They come with a flexible tube spout for squirting the Oil into the Box.
    Check and fill it according to the instructions in the post above.
  13. hays1530
    hays1530 New Member
    2005 VZ Calais
    Awesome. Thanks for the help guys. I'll give this a shot and update you all with how I go. Cheers
    Vsboi likes this.
