tremp gauge problems
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by bopski88, Aug 21, 2008.
  1. bopski88
    bopski88 New Member
    vs executive
    some advice would here would be helpful on my v6 vs the temp gauge after warmed up will go all the way up to hot then come back down then sometimes it will stay normal and sometimes it will keep going up and down has been doing it for a month now any ideas on what it could be ?
  2. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    Thsat could be considered normal - in traffic the fans will only turn on when the gauge reaches about 3/4 then will cool to 1/4. If moving without stopping the gauge may stay on 1/2....maybe more information is required.
  3. manual_vr
    manual_vr New Member
    VR manual
    im having the exact same problem
  4. Niggadore
    Niggadore New Member
    Seaford, Victoria.
    1996 VS Caprice V8. 1996 Proton satria.
    Is it a series one or two VS? The series two has a two stage fan...
    Before i had a major service on my car, the temp guage would rarly hit half way unless i was sitting in traffic in Drive gear. or a hot day.
    I had a service last week, and a new temp sensor put it, and after ten mins of driving, the guage reads half...
    So, this leads me to think these guages are somewhat dodgey.
    Your's might be buggered. but i'm no mechanic.
    But like hako said, this could be normal, i just don't know what normal is anymore....
  5. gendi
    gendi Member
    Cessnock, NSW
    06 VZ SVZ Wagon
    i just replaced my thermostate today and now the temp gauge goes up to half then back to 1/4 when driving, before it only went to 1/4 unless idling in traffic where it went to 3/4 then down to 1/4
  6. bopski88
    bopski88 New Member
    vs executive
    hey worked out the problem low water in the radiator mine has a minor leak so over time it has drained out causing the problem so just fixed the leak filled it back up and problem solved thanks for the help
