Trick to disable the heater without anyone knowing?
Wheatley098
30
Australia
Commodore VE SSV Ute
Long story short my other half likes the heater on in the car and it ####ig kills me! Is there any way possible to disable the heater or the whole fan system I really don't care, is there a fuse I can pull or something easy?
Cheers guys
Sent from my iPhone using Tapatalk - now Free
Sabbath'
Redblock Jesus
80 Series// VFII Black Edition
Put split zone climate control in. Problem solved.
mikey-
Perth, WA
VE SS Sportwagon
Upgrade to the new model... new model missus that is...
Wheatley098
30
Australia
I don't have climate control at all so splitting it would do nothing
Asmodai78
VE Calais V Sportwagon
I have a simple rule in my car when I'm driving, DON'T. ####ING. TOUCH. ANYTHING!!., I don't care if your god, if your cold ask to put the heater on, if you want to change the radio or cd ask, if you want to move the seat back ask, remember its all about DRIVER comfort not passenger comfort.
Darren D
VE SS Z-Series 6M Sedan
If you do want to do it, the best way will be to inhibit the operation of the heater hose valve.
The heater hose valve looks like the image below, it operates on vacuum when the heater is on, allowing hot engine coolant to flow through the heater core.
If you put a tie-wrap around the mechanism it will prevent the valve opening without doing any harm.
Darren
Mk2
VX Calais S2
Tell her you're the man and you're in control. She should beg if she wants the heater on, right? After all, you're the man.
PIR4TE
Banned
AWOL with Ari
Black Pearl
^^ that's assuming you are the one driving... and wearing the pants!
anarklov3r
2007 WM Caprice
Grow a pair and say "Hey wife, can i put the heater down? im melting away here..." or you can disconnect the vac hose to the heater tap, remove the blower fuse, remove the stereo fuse, or put something foul smelling in the heater so she wont want to use it. Even better, just open the window?
