trip computer
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Brendo169, Mar 6, 2010.
  1. Brendo169
    Brendo169 HSV Porn
    WA
    VS Senator
    just wondering what wires are needed for the trip computer to be working in a vs clubsport auto
    before today it has always worked... but through my aggressive fiddling with electrics in an attempt to install a speedo corrector i must have knocked a connection that controls the trip computer. just wondering what coloured wires i should be testing....according to the wiring diagram i have a yellow wire with black stripe controls the trip computer
    http://www.memcals.com/pdf/VSV8 Manual Wiring Diagram.pdf
    can some one else confirm this with me???
    where should i be looking for loose connections because i find it hard to believe that that one wire controls the odometer, fuel consumption gauge and trip computer all at once...
    any help would be greatly appreciated!
    thanks in advance
  2. Brendo169
    Brendo169 HSV Porn
    WA
    VS Senator
    sorry forgot to mention that nothing shows up on the three little displays underneath the tacho and speedo....its just blank...but it worked before haha
  3. 88GreenVN
    88GreenVN Next Exit Left
    Surprise, Arizona
    Dodge Ram Van 1500 5.2 V8
    The 4th plug probably is out.
    You need to test the orange/white to power up the ODO.
  4. holdenman308
    holdenman308 Member
    Qld
    holden vn wagon
    have you got the small white plug, pluged in the buttom of the speedo if you take the fuse cover off and look up to where the speedo is you will see if its pluged in or not if its not im not relly sure ( iv put trip computers in all of my vn-vs iv owned and thats the only thing that had me stuffed when i did the frist 1)
  5. Brendo169
    Brendo169 HSV Porn
    WA
    VS Senator
    yeah that plug is definately in!!
    88green VN
    what do you mean by the 4th plug
    how would i go about testing the orange white wire
    im sorry im quite new at auto electrics....i wish i new more!!!!
    thanks
  6. 88GreenVN
    Surprise, Arizona
    The 4th plug - goes in the bottom of the cluster.
    The orange/white and black/white power the trip computer up. Find out if you have power at the main plug for the dash loom. If yes go to the 4th plug and see if you have power there.
  7. Brendo169
    Brendo169 HSV Porn
    WA
    VS Senator
    your all going to laugh but it turned out to be a fuse
    when it first happened i checked the fuse and it was good
    then i discovered that the 4th plug was out...so i plugged it back in thinking that it would fix the problem
    haha then doing that must have blown the fuse!!!
    quite embarassing...glad it was something small!
  8. 88GreenVN
    Surprise, Arizona
    OK we will have a little laugh - cheers :)
  9. Fekason
    Fekason Fekason
    Penrith NSW
    Yes, I will laugh, but with you, not at you. I know the relief when a problem turns out easy to fix.
  10. Brendo169
    Brendo169 HSV Porn
    WA
    VS Senator
  11. 88GreenVN
    Surprise, Arizona
    funny because we have all done it before at some point :)
