trip computer
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by vracclaim, May 17, 2006.
  1. vracclaim
    vracclaim Guest
    I have a VR acclaim, Just wondering if its possible to stick a trip computer from a VR berlina into an Acclaim. Has anyone done it. and how would i go about doing it.
  2. Infus10n
    Infus10n New Member
    Holden Captiva (Work Demo)
  3. fitzy2005
    fitzy2005 New Member
    Wide Bay, Queensland
    VY S2 Berlina
    as infusion has said yes its possible, hardess part is getting the wiring harness for it.. but do a search and itll tell howto do it, and if in trouble ask infusion or markovr, they helped me :)
    (damn work is so boring)
  4. Fekason
    Fekason Fekason
    Penrith NSW
    Wiring Patch harness
    The hardest thing to obtain is the patch harness.
    If you can't source a used one from a wreckers, let me know. I can provide a part number for a HSV harness that can be used to make the necessary patch harness, cost less than $100.
  5. vracclaim
    vracclaim Guest
    Thanks for the help guys.
    this seems a little bit over my head.
    i think that i will leave it for now.
  6. shaggerz
    shaggerz New Member
    Victoria Point, Brisbane
    2004 VY2 SV8 A4
    I have just done this one myself. Its very much a worthwhile mod to do, and of course now I know how to do it, I can make the harness up easily. If you get the parts, I can modify the wiring harness for you if you're in Brisbane, or failing that I can offer help. It's really not difficult at all when you know how :)
    You'll need:
    1 x Instrument cluster wiring harness from a VR/VS Calais or Stato
    1 x Level 3 Instrument Cluster from VR/VS. VN/VP one is similar but wiring is different so you can only use VR/VS one.
    1 x Trip computer button module.
    I got most of that from my local wreckers for about $200, and for $12 from eBay I got the trip computer buttons. This mod is definitely worth the effort and can be completed in a lazy half a day from start to finish if you know the tricks :)
  7. VTS5
    VTS5 TechJunkie
    Sth.East\Melb
    VE OMEGA 3.6L Dual Fuel
    I'll like to take you up on your offer if its still available :bow: Where do i start from???:dance:
  8. vracclaim
    vracclaim Guest
    i will also take you up on that offer. i will start to source the parts over the coming weeks.
  9. shaggerz
    shaggerz New Member
    2004 VY2 SV8 A4
    OK give me a few days to make up a diagram... markovr gets 100% of the credit for working this out, but it took me a while to understand his diagram so I will make my own up for you.
  10. markovr
    markovr Well-Known Member
    northside brisbane
    07vessv 94vr .04vz wgn,93vp wgn,82 vhV6 wgn 88 vn
    Cant you read shaggy....no one else complained and plenty of people have used it.
    Should I rewrite it in single syllable words for you .
    Just Joking
  11. VTS5
    VTS5 TechJunkie
    Sth.East\Melb
    Well i've got everything ready and still waiting.
  12. shaggerz
    shaggerz New Member
    2004 VY2 SV8 A4
    Well, I was going to do that, but since markovr seemed to take exception to that you can refer directly to this thread:http://forums.justcommodores.com.au/showthread.php?t=994
    where markovr describes the process himself and provides diagrams. If like me you are an idiot, and struggle to decipher the diagrams, then I can clarify.
    Good luck and may your dash be sexy and computerised.
  13. markovr
    northside brisbane
    I dont care what you do with the diagrams to make it easier Shaggy if it helps another member understand them....I just thought if you were a technician of some form like you say it wouldn't be too hard but if I complicated inadvertently something in my description fix it so it is easier to understand.
  14. Torquen
    Torquen Boost FTW
    Perth, WA
    450+ HP FORD XR6T
    quick question... iv got a v6 lvl 3 dash atm and im about 2 atempt to install it but next year im planing to put a v8 in my car...now would this mean i would have to source a v8 level 3 dash or could i just use the v6 levl 3 dash?? cheers fellas.
  15. shaggerz
    shaggerz New Member
    2004 VY2 SV8 A4
    i *think* it is possible to modify a v6 cluster to accept a v8 signal, but I do not know how to do it. I know it is possible to modify a V8 cluster to work with a V6 by adding resistors, so I can only guess that something similar can be done with a v6 cluster to make it work with a v8 motor.
  16. Torquen
    Torquen Boost FTW
    Perth, WA
    450+ HP FORD XR6T
    k, cheers m8. its just i was thinkin if im going 2 do teh mod now id like to not have 2 do it again in 6 motnhs time.
  17. shaggerz
    shaggerz New Member
    2004 VY2 SV8 A4
    Far easier to wait I reckon...
    This mod was WELL worth it for me though... fantastic addition to the car :thumbsup:
