Trip meter hidden extras
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by Barbieros, Nov 28, 2006.
  1. Barbieros
    Barbieros New Member
    VIC
    VX S pack
    Hi guys,
    Was mucking around with the trip meter on my new VX s pack. If you have the car off, and hold down the MODE button, turn the car on, and (still holding mode) press the up arrow.
    Its got all sorts of goodies in there like voltage meters, digital readouts of rpm and speed, but there's a couple in there that i would like to know what they are. The first readout i get is 9960980, i have no idea what that is.
    I've found an article on autospeed whcih is suppose to explain it all, but u have to sign up and pay $6.
    Just wondering if anyone can help me out so i can save my $6 and put it towards the $70 i just spent of fuel. (still getting use to not being able to fill up the 4c for $40... optimax)
    http://autospeed.drive.com.au/cms/article.html?&A=195
  2. djlingard
    djlingard New Member
    Barcaldine
    VZ Executive
    Do a search of this forum this has been covered many times before:thumbsup:
  3. Infin8
    Infin8 VXIIBerlina 'Chrome Spec'
    VXIIBERLINA
    SPD 0 km/h (Digital Speedo)
    T 26 C (Digital Temp)
    V 12.2 (Digital Volts)
    7.5 L (Remaining Fuel)
    F 0.0 L/h (Litres per Hour)
    vb 5.0 (Voltage to the BCM)
    EOO nu (Trouble codes in the computer)
    screen returns to normal once the ignition is turned off or if you press the up and down arrows together.
    thats just a few, hope it helps in some way....
    Cheers,
    Infin8
  4. bassmansimon
    bassmansimon New Member
    VX S 5 speed
    like djlingard said, it's been covered before.
    but here's some info i think you might find helpful:
    ps you don't still have to hold mode while you are pressing up. i think once you are in the "secret codes" section, just pressing mode will change through them.
    Initial Display=Software Date 980729 29/07/1998
    Part Number: Pn5353
    Mode Switch Voltage: v- - -5.0
    Battery Voltage : vB 14.3v if you press the Arrow UP you should see another voltage -U-2.5V this is for the Up voltage of this button operation.
    If you press the Arrow DOWN you should see another voltage --d 1.6 V this is for the Down voltage of this button operation.
    Petrol Sender Voltage : vP 2.3v
    LPG Sender Voltage : vL 5.0v
    Remaining Fuel: f 48.5 l
    Instantaneous Fuel : f 2.1 l/h litres per hour and once driving it will change to litres per kilometres.
    Coolant Temperature: 98 c
    Speedo: 35k/mh
    Tacho: t 3500
    Park Lamps: P on / P off
    Dash Trouble Codes ( Press Up/Down to Scroll Through) E00 - -E01- - E02- - E03- - through to E31
    The last display will cause the WHOLE display to GAUGE TEST itself, by lighting up all internal lights and move all temp, tacho, speedo, and fuel to middle range, extra lights like LPG and ABS will be tested by this and plus the buzzer will sound as well.
    The last step and this is to reset your computer back the normal DISPLAY, this is done by holding both up and down arrow together. or just turn off your ignition and when you re-start your car it will come up normal.
  5. don0xer
    don0xer Member
    2000 VX Calais 3.8L Supercharged
    Ive been after those definitions for a while now thanks :)
    My first voltage measurement is 13.7 - 13.9, is that acceptable as normal ?
    Also on the 3rd window on the 2nd row (vl 5.0 / bv 5.0 /fuel) it sais my fuel is 3.0. This was around 1.6-2.0 BEFORE i changed my exhaust/oxy sensors, what is this measurement for (this is not the inst fuel usage)?
    With the error codes
    t03/04/05/06/07/21/22/23/27/28/29/30/31 all had (nu) next to them
    t17 had a (hd) next to it, the rest of the numbers didnt have any letters after them, are they a diff form of extracting error codes from the computer? because i tried to check the error codes after doing this with the normal bridging 5/6 terminal method, but the light would flash at me once- continiously, not denoting code12 or anything :/
  6. Hairy Eater
    Hairy Eater Banned
    Queensland
    2000 VX Executive V6
    maybe better to ask Doc Bob
  7. bassmansimon
    VX S 5 speed
    sorry mate
    yeah try dr bob.
    i dont really know about the error codes
    according to the info that i have been given, vB is battery voltage. yeah - 13.7-9 is fine i think.
    apparently vL is LPG Sender Voltage
  8. Murdoch
    Murdoch Active Member
    VF II SSV Wagoon
    I dont reckon the l/h function turns to l/100km once moving.
    There is no way i can only be using 4.5l/100km in my 350 when cruising at 60km/h.
    I always assumed it was 4.5l/h which equates to 7.5l/100 which is more realistic @ 60km/h
  9. bassmansimon
    VX S 5 speed
    yeah that makes sense
    i didn't make up that sheet it was just info which was given to me.
    sounds like what you're saying is right
  10. WAGON MAN
    WAGON MAN Gas Sleeper
    North Coast , NSW
    VX S2 Berlina Wagon with Phreddied bits.
  11. Doctor Bob
    Doctor Bob Grandpa
    Retired
    RG. Colorado & Caravan
    The codes displayed by the instrument cluster are not PCM codes are they?
    its like looking in the pantry for frozen food if you get my drift
    all the modules in the car have the ability to log diagnostic codes
    Rob
  12. Christina
    Christina Banned
    Almost genuine VT "S" + VZ "SS" Red Ute + Vk V8
    i was using this a few weeks ago and one of the options said "v5" does that mean i'm running on 5 cylinders?
  13. wrx884
    wrx884 WA's ASR Rep
    VT Exec/ VT L67 Spac, 5L VP Calais, 77 TC Gemini
    lol im sure ud know by the running of ur engine if u were running on just 5 cylinders lol so no
  14. TigerVX
    TigerVX New Member
    2000 VX Commodore
    Rob, Do you have a list of what these dash error codes are?
    Cheers.
    Chris.
  15. Doctor Bob
    Doctor Bob Grandpa
    Retired
    here is the DTC list
  16. beeks
    beeks Banned
    N.S.W
    XR6 5sp MKII + DR 600S
    It mean's your running on 3.Get it to your nearest Holden dealer...Pronto.
  17. Christina
    Christina Banned
    nahhhhhhhhhhhh holden are rip offs
  18. wrx884
    wrx884 WA's ASR Rep
    lol u should really have 3 left hahahaha
  19. xwgs351
    xwgs351 New Member
    VTII ACLAIM
    I havent been in to see my error codes yet but all of my warning lights come on and also the fan, some times its fine but most it goes gaga anyone have this fault??? (also the aircon decides not to work when the warning lights lights are on) rough guess id say its the temp sensor
  20. Doctor Bob
    Doctor Bob Grandpa
    Retired
    doubt if its the temp sensor, more than likely an ABS module fault
    does the oil light come on as well?
    Rob
