Trouble when starting
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by CMA, Nov 27, 2008.
  1. CMA
    CMA New Member
    VZ SV6
    Two mornings in the last week and a half i have gone to start the car to go to work and turned the key and it didn't start. All accessories came on as usual but it didn't start, and got a message on the computer displaying "service vehicle soon." I've then turned the key to off and tried starting the car again and no worries.
    Anyone know whats up?
    It's not due for a service for another 6-7000 kms.
    It's a 04 SV6 by the way.
    Thanks in advance
  2. dans_vz
    dans_vz Active Member
    Swan Hill
    MY16 VFII SSV Redline Manual & 05 VZ Calais daily
    I had the same problem. It turned out to be the metal ring that the key head comes in contact with at the ignition. Had this replaced and haven't had a problem since.
  3. crewzincool
    crewzincool New Member
    VN-V6/2005 SV6
    clean your battery terminals aswell
  4. andyman
    andyman The Only 6sp VZ Wagon
    Orange, NSW
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    well service vehicle soon means it has a not emmisions related fault coded logged,
    id start by disconnecting the battery, than clean the metal ring on the ignition barrell, just levering it out a little aswell, clean the metal contact on the key head, and while your there clean the battery terminals and reconnect, see how it goes.
    is the key head still operating correctly?
  5. CMA
    CMA New Member
    VZ SV6
    doesn't come up all the time though...
    yeah it is.
    cheers guys will try what you suggested on the weekend
  6. andyman
    Orange, NSW
    some fault codes may clear themselves if a reference that is needed returns next ignition cycle
    the code will still be logged but stored in a history section, not in the current
  7. tmaybz
    tmaybz New Member
    Wollongong NSW
    VZ exec 05, VP exec. wagon
    don't disconnect the battery unless you have the security code for the sterio system
  8. andyman
    Orange, NSW
    you wont need it for a vy/vz/ve, the radio is linked with the bcm, it will remember the code unless you pull the radio out
