and it works well too! also the air con (wind the window down) works just the same, pity the passenger side is jammed.
my fuel gauge doesn't work but all the rest do, I would find pretty hard to match engine revs to road speed if they didn't, crunch, crunch, crunch I better go back and pick up the pieces.
Jeez ur spoiled, our one was an ex garbo truck.
It's faults are: No functioning tacho (took me 3 10 hour days to be able to get perfect downshifts by feel) no speedo (gps isn't instant so you can't rely on it for accurate speed when downshifting.
8 spd crash box and the splitter switch leaks air so if you dont drop down to bottom box before you stop you'll have to force a 5th gear take off which isn't easy with 10-12 tonne of ice in the back.
on some of my routes, i have to stop and shift my load over the back axles to get up hilly roads like killcare or patonga
the turning circle is that bad that most average 2 lane roundabouts require a 3 pt turn if you're stupid enough to do a u-turn using a roundabout! Hell it's lucky to get around most smaller 2 lane roundabouts when turning right!
No AC
Gutless motor which is freshly rebuilt (cost the boss $10k when for an extra couple of thou he coulda dropped a bigger capicity cummins into it and it wouldn't be such a slug)
Feels like you need to shift gears with a lump hammer and the added bonus of having a cash safe right at your elbow (mounted on the risen section next to the drivers seat) so if you're not careful or if you're overzealous with the shifter you smack your elbow on the safe.
The seating position vs shifter and steering wheel with 53 kg little me at the wheel reminds onlookers of the guy in the indianna jones movie who was driving that tank (in the last cruisade)
The air ride seat is broken so you smack your head into the roof all the time
That horrible vinyl rooflining is falling to bits so the crumbling foam between it and the metal roof float around the cab and into your eye's
The rear brakes lock up when you've got no load onboard.
The dash looks like it's stolen from a 1960's leyland bus (sheet metal covered in fake woodgrain vinyl like old speakers, holesawed gauges)
and here's the kicker: it's a '96 2250D!!!!
