Mate we are talking at cross purposes - flow at head (per bank) versus engine flow. Agreed, induction on a stock LS1 needs much less than 450 CFM at 1 psi, max lift, agreed (all above figures are 28" h2o).
My point is the ridiculous focus on pre-TB flow which is at least 2x overkill, sold on the premise that the proof of benefit is a dyno chart showing hp with IAT corrected to J607 (15.5°C). The reality is that these OTRs are tested at 18-25°C but run at least 2x as hot as the ideal shown on the dyno, up to 5x in my experience.
Where do I source the 1400 CFM OTR claim? Well,
they all do indirectly by assuming one manufacturer's research claim then proving their slightly modified trumpet makes denser air, by way of print out using a corrected dyno. This is typical
Vararam VR-G8 Ram Air Intake System - 08-09 G8 GT GXP - PFYC.com
My point is that replacing the MAF is with a better unit in a less restrictive housing is a good move, while time spent deliberating which brand of plastic trumpet sitting on top of your radiator will give the best hp gain as shown on the marketer's dyno is a furphy.
All 'independent' tests I've seen are not real world rather clinical, as 95% of the time you get IAT 40°-70°C and like ConstantVelocity mentioned this can make your MAFless tune wander like a drunk in the sun.
I follow G8 guys in Nevada / Arizona and the Carolinas who get some of the best
real world results by keeping the MAF / temp sensor away from heat directly behind the radiator at the top of the engine bay.
