Trying to Fix Problem, Size Earth
COMMY VP 666
COMMY VP V6
COMMODORE VP
hey all
what size earth is best for car stereo amp?
thanks to all
Trayner
Fresh prince of Pakky, Gangsta
Gangsta Hundy
well its best to match the same size wire as the power cable that your using for the amp
lil_mickey
LOUD AND PROUD
33
Geelong; Victoria
VH 253 :-)
as a minimum... can be bigger if you want... and make sure you earth it to a solid steel place with nut and bolt preferably.
COMMY VP 666
COMMY VP V6
COMMODORE VP
yeah i got annoying buzzing, whats a good size for power and earth, lil bit more than minium for no problems.
what size you recon?
hakhawk
smooth moderator
Staff member
35
what size amps are you running now?
are your rca's on the same side as the power cable?
holdenboy
Custom Car Stereo Systems
39
Nelson Bay NSW
VR Wagon
Upgrading the size of your power/earth cables generally wont get rid of "buzzing" or engine interference (unless your using like 16awg cable). As a minimum you want to use 8awg power/earth cable.
Normally this is caused by a poor earth connection. Make sure you sand/scrape back the area to bare metal, and as lil_mickey said earth it to a solid part of the car. The rear seat belt bolt is a good spot.
COMMY VP 666
COMMY VP V6
COMMODORE VP
yeah nah iv done everything possible to stop it
last thing is putting proper cable and a bigger earth wire at the cd player unit
VH SL/X Wagon
What model amps, and is it 1000w RMS or 1000 peak/max/pmpo? If it's RMS you'd want a 4gauge earth each.
Fun_Bucket
35
Cairns White Rock
Cruze II sri
What do you mean buzzing noise, from the speakers do you mean while the music is playing??
