trying to pick the right cam for my ve ss
crim
ipswich
2012 ve ss sportswagon 6 speed manaul
Building a ve ss sportswagon looks tuff but I need it to sound and go just as good won't to stay na. Car is more of a show car so divability is not. Important won't to go a real big cam just for the lumpy sound been told a 232/234 would be the way to go. Going to be running lea cnc ported heads otr for kit 1 7/8 header pipes into twin 3 inch it is a 6 speed manaul. Any help would be great
blackve76
45
there
VE SS ute 360rwkw N/A, 2016 VF2 SS M6
232/234 is a ls1 cam due to the large intake valves something like a 231/239 is better(bit more split)
Heron SSV
Central Coast
GMM Turbo Killer cam, or the VCM 24 cam (237˚ 248˚). Or you could ring some shops and ask for the biggest f*ck off cam that'll fit a motor with a stock bottom end and head work.
crim
ipswich
That's what they reckmend to run but I thought I could go bigger Wonted a second thought. Hores power wise they said should be 450/500 range is that correct
Cava454
33
Box
VR SS, VZ SS
My mate is selling brand new cam gear for VE. It's fairly big. Was goin to make around 320/350rwkw. I can ask him if u want
Heron SSV
Central Coast
yep that power is about right, depending on the tune/dyno as they are all different. WogBoyz has a ve ute with heads and a decent sized cam plus full exhaust and is making 471hp at the wheels
mikey-
Perth, WA
VE SS Sportwagon
Some of the LSR comp cam's are specced with a nice split duration and have huge duration and lift.. PTV clearances would be... interesting?
235/243 0.621 0.624 @ 0.050
239/247 0.624 0.624 @ 0.050
Maybe look at some shorter diff gears (3.9's 4.11's?) too if it's just a weekend with a huge cam.
Gonna be a abit of a pig down low, not that it matters for a weekender though....
Heron SSV
Central Coast
you could also get a smaller cam and have it tuned to give a bit of lumpiness.... it'll make it a bit nicer to drive as well but still give good power
