have done some work to the motor and its not running as it should..
gday mate
the cars not driven on the road it's just for the drag strip, so this is a list of what we have done
it takes a bit to start 2 or 3 go's before it wants to idle
heads ported & polished
high ratio rockers 1.9:1
69mm throttle body
plenum spacer 12mm
manifold insulator 12mm
performance plug leads
iridium plugs - 2 stage colder
custom intake & pod filter
NOS sniper efi wet kit (100hp)
pacemaker extractors
custom exhaust (no catalytic converters)
Auto has had work & shift kit fitted
Diff has had mini spool fitted
it started at 17s now its last pass was 13.2s at 102mph
after that pass i did the heads and now its doing low 14s, and losing power at the end of the track,
it feels like it staving for fuel.
It's like the computer doesn't no what's going on ?
thanks
