Turbo Ecotec blowby
Discussion in 'V6 Development And Modification' started by Avi8or, Mar 12, 2012.
  1. Avi8or
    Avi8or Luxo-barging
    WM Caprice 6L
    Hey guys,
    My turbo build is finished, VS T5 Ecotec running about 7psi. Thing is quite good and happy, but I am noticing after running it for a while that the breather on the rocker cover is venting small amounts of what I assume is blowby smoke. I took the PCV and closed it over when I built it so it shouldn't be leaking. The engine is only about 7000km's old, is this something that I should just expect?
  2. delcowizzid
    delcowizzid on holiday
    NZ
    в∞ѕтεכ √&
    as long as it aint puffing out its probably been real rich or is rich and filled your oil with fuel via the ring gaps. it evaporates out when you stop.i would probably give it an oil change if it has.or your turbo ex housing is getting real hot and superheating your engine oil thats returning to the sump
  3. Avi8or
    Avi8or Luxo-barging
    WM Caprice 6L
    The tuner did tune it on the safe side, so that may explain it. Its not heaps, just wiffs for probably 30 seconds after pulling over and then once the engine is shut down it stops all together. Would it be a good idea to plumb it between the filter and compressor inlet so that it recircs like the original PCV would?
