AirStrike
- Jun 28, 2003
- 8,197
- 1,222
- 113
- Age
- 38
- Location
- Melbourne
- 91' VN SS
Just a few things, 200rwkw from a boosted 6 is going to cause one of two things a stuffed stocker or an expensive build up.
Another thing to think of, the shift kit doesnt provide any extra strength at all if only effects how it shifts.
Main question, how much do you know about turbos? Because runnin a T3 60 trim at 3psi is wayyyyyyyy out of the best efficiency on its efficiency map. Its way in to the left in the surge limit area which limits power and as the name implies cause the turbo to surge as you have too large a turbine wheel for the exhaust to keep speed up to spin the compressor wheel.
To make the power you want with that turbo you are lookin at in its peak efficiency you would be looking at around 10-12psi.
Search on the net and learn how to read efficiency maps, will help with your choice alot.
AirStrike :air:
AirStrike :air:
