Turbo v6 exhaust size???????????
Blakvsexec
5.0L VS EXECUTIVE
My turbo has a 3" v-band outlet, should i continue it at 3" all the way through
or
Should i reduce it back down after the dump pipe
I know on diesels the exhaust should be free flowing on a turbo engine but is it the same for a petrol engine???
2DIE
ONEDOLLAHOLLA
South Aus
www.torn.com
97 Acclaim
I think twin 2.5" or a single 3" should be fine from reading about 100 of these posts :p
Blakvsexec
5.0L VS EXECUTIVE
A twin 2.5 is bot possible as i am only running a single turbo and only have a single outlet
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
soop
Banned
Smithton, Tasmania.
2003 SS Commodore Series II
Turbo exhausts have totally different princible's.
Run a single 3" as a minimum.
Or depending on boost and HP, 3.5" tapering to a 3".
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
still just the same principle i went from 2.5 to 3" and lost low down torque cruiseing but gained heaps 0-100 at full throttle you still get a trade-off just like N/A and with some extra timing you can make up for the torque loss down in the cruise area
soop
Banned
Smithton, Tasmania.
Totally depends on the turbo really.
Better idea is to go 3" tapering to 2.5 if you're only running a mild setup.
Also, the Dump pipe design is critical. I've seen some **** dump pipes being used on Commodores.
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
7psi you strangle the **** out of them with 2.5" exhaust ive been looking at 3.5" or 4" for a while now to open it up some but 3" is good for 11's so far see what difference it makes straight out the dump in a month :D
soop
Banned
Smithton, Tasmania.
Becarefull that it doesn't surge like a mother with no exhaust on it ;).
How have you delt with the waste gate, is it internal or external?
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
it has good enough fuel in it that it could surge to 18psi and survive pretty well on its own :D wastegate cheap as chips chinese special 38mm never spiked in its life
