turbo vs v6
Discussion in 'VR - VS' started by p_schrapel, May 16, 2010.
  1. p_schrapel
    p_schrapel soon to be big turbo
    vs commodore
    Model: vs v6 accliam
    Colour: dyamic white
    Bodykit: just the s pac boot lip
    Engine: ecotec
    Engine Mods: diamond forged pistons, intence racing rods, line bored, main studs, head studs, o ringed block, copper head gaskets, stage 3 intence racing cam, port and polished heads plus intake manifold and plenum, 660cc injectors, bigger fuel rail cross over plus bigger inlet and outlets welded onto fuel rails, pro flow turbo kit, gt35/40, turbo smart 50mm wastergate, 3 inch dump pipe, screamer pipe, electric water pump, no power steering, double valve springs, removed balance shaft, double row timing chain, powerbond race hymonic balancer, mafless tune, all that all i can think of at the moment
    Power: dont know yet just putting it all back together getting it painted then getting it tuned
    Exhaust: full 3 inch dumper at diff with 1 muffler
    Gearbox: yeah i know its weak but a T5 with a billet rip shifter and cushion buttom clutch
    Diff: IRS with mini spool and 3.9 diff gears
    Brakes: vt brakes up front with slotted rotors and standard down the back
    Suspension: superlows
    Wheels/Tyres: interceptors with 8 inch wide on the back and 6 on the front
    Interior: vy ss leather seats front and back, white dash with e boost controller moulded into it. calais console modified for manual selector, 2 gauges moulded into where the air bag used to be on passenger side and white inserts on door trims
    Stereo: pioneer head unit, jcv front speaker, kenwood 6 by 9s in the back and a kenwood sub and 2 amps, all up cost me $300 so cant complain.
    Other Mods:altezza front headlights and indicators, ariel hole removed from gaurd, vt side indicators, exhaust port removed from rear bar, front fog light holes removed from front bar, calais front bar grill insert, cooler,
    Other Features: electric windows and that about it
    Future Plans:
    VR/S SS Bodykit,
  2. braundog
    braundog Member
    sunnycoast
    Vs Holden ute
    nice mate, ive just finished my build , its in the shop at he moment getting 3 inch mandrel put on. my motor is stock thow.
    ive got same setup as yours, how much roughfly have you spent on the intternals for your motor mate , as i know mine wont last too long.
    only running 6 psi .
  3. WogBoyz
    WogBoyz 435rkw/590rwhp
    Cairns, Qld
    08 VE SSV M6 Ute
    sounds like a beast mate! i didnt know they had mafless tunes for the Ecotec's
  4. p_schrapel
    vs commodore
    ummmm how much well i dont want to say but for all the internals close to $5,000 but the exchange rate from the states was **** at the time. plus u have to add on machining and gaskets and that. horse power factory can do mafless tunes on the ecotecs. they did it for me when i used to have it supercharged and i didnt have a problem with it. 6psi u should be fine mate. im planning on running around 15 when i drive it and maybe 20 when i take it to the track
    it get painted on the 29th so i will have more pics up of the body all together and how it all looks. how much is your exhaust setting u back. i still have to get mine made up
  5. braundog
    braundog Member
    sunnycoast
    Vs Holden ute
    my exuast is costin 550 and its for a vs wagon. when this block hits the wall im thinkin bout building a low comp block so i can wined the boost up, i know ill get board of 6 psi eventually. ive got my photos of my build up in v6 performance section.
  6. p_schrapel
    vs commodore
    ohhh i had 160rwkw with my supercharger setup and got bored in a week with the power so bigger is better i always get told.lol ill check your ride out
  7. p_schrapel
    vs commodore
    by the way wat fans r u running on your car seeing as u have the turbo in the same place as mine the standard ones wont fit
  8. braundog
    braundog Member
    sunnycoast
    Vs Holden ute
    yeah nice. need to post up some more pics now she is finished..... will do it this week i think!! if i get time.
  9. braundog
    braundog Member
    sunnycoast
    Vs Holden ute
    ahh i just got a 16 inch single slim line fan.. only been for 1 drive but she didnt heat up at all. tried to cut the original fan shroud but still wouldnt fit!!
  10. p_schrapel
    vs commodore
    yeah. im thinking of getting 2 fans off the front of a vr commodore. they r about 16 inch slim line fans. il find out 2morow when i go to the wreckers
  11. braundog
    braundog Member
    sunnycoast
    Vs Holden ute
    should be able to fit them easy as. if not just go two 14 inch
  12. acarmody
    acarmody Donati..Whoa Green
    VX Berlina
    Nice work mate, I like the interior conversion. Just one question, does that steering wheel still have an airbag?
  13. p_schrapel
    vs commodore
    hahahaha no it doesnt have a airbag so its not road worthy. its only a **** steering wheel i had floating around. i plan on getting a nicer one when the car is just about on the rd. ill get some good seat and interior pics once its painted after the 29th so i will have all my door trims in and that. but i dont think any of my car is road worthy any more so why bother with just a steering wheel.
  14. delcowizzid
    delcowizzid on holiday
    NZ
    в∞ѕтεכ √&
    about time you put the car up :D
  15. p_schrapel
    vs commodore
    hahahaha yeah took me a while. but the engine has been sitting in the garage for the past 4 months pretty much as i lost interest. but pissed off the gf and need a car to have fun in and pick up in.lol the little ford laser just doesnt do it for me anymore. i need to get back in my commodore and do wat i do best. lol should be running and on the rd in under 2 months if i keep ontrack with it like the past 2 weeks. ill have to put up the dyno paper when it gets tuned to let u know wat it makes on big boost
  16. p_schrapel
    vs commodore
    got my clutch today and fitted my gearbox and modified calais console to fit manual shifter. goes to get painted this weekend and ill put up some new pics how its all coming along
  17. p_schrapel
    vs commodore
    more progress done, only thing left is water lines, exhaust thermo fans and tune
  18. Jonnii
    Jonnii Member
    Victoria, Melbourne,Croydon
    VE SSV Z-Series Ute
    looks very nice. Something id like to do in the future. turbo my ute. That front bumper is interesting i like it. should have got the mould line filled in at well.
  19. delcowizzid
    NZ
    в∞ѕтεכ √&
    good to see you masked up the wheels and tyres before painting LOL
  20. p_schrapel
    vs commodore
    the wheels are buckled. i got them off a written off commodore i brought for parts. lol getting thrown out soon. i was thinking about getting rid of the body line but i used photoshop and it didnt look right. im thinking if i should either i should run a calais side mould or a vs s pak mould. any opinions would be good
