Turning on headlights blew my amp fuse
BoB G
New South Wales
Lg2 vs ute
I had just finished wiring my amp and sub up tonight at a mates and when I left it was dark so I turned my lights on and there was a massive spark and my amp now has a blown fuse. I’m not going to put a new fuse in till I get to the bottom of the problem just wondering if anyone has had this happen before
BlackVXGTS
Melbourne, SE
You may get a better (quicker) answer if you post your problem in the Electrical Wiring or Car Audio forums.
Sabbath'
Redblock Jesus
80 Series// VFII Black Edition
How did you wire in the system? More importantly, the illumination part.
CCCMikey
Black Mountain NSW
VS '95. LPG. 513,000KM
Some sub amps have a rather large capacitor in them. A fault in another circuit may cause that capacitor to discharge dramatically - the sub amp might not have been the cause of the fault. Only a guess though.
losh1971
North Tas
VE Series I SS Ute
I'm no expert but since an amp should be powered straight from the battery it would seem odd that blew the fuse as a result of turning the lights on. Unless it has something to do with the switch wire but even then a VRs circuitry is fairly basic compared to later models.
