Twin fans on VP?
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by cruzncommo, Apr 23, 2007.
  1. cruzncommo
    cruzncommo Banned
    QLD
    VP 5spd
    will the twin fan thingoes on the AU falcons fit a VP? and would they be hard to fit/wire up?
  2. nsladden
    nsladden GET UTED
    Murwillumbah
    1992 Holden VP Ute S 5.0L & 1989 Holden VN 5sp Wag
    Im not too sure. Have you checked the dimensions? Wouldnt it be easier just to get a Davies Craig (or the equivilent) fans wired up?
  3. potshots007
    potshots007 New Member
    Mildura
    VN series II custom :) and VZ exec
    yeah shouldnt be too hard, they probably wont fit straight up but with a bit of cutting or adding in places, im sure it would work, as for wiring it up pretty sure there are only 2 wires on the Vn and 2 wires on the au fans
  4. cruzncommo
    cruzncommo Banned
    QLD
    VP 5spd
    hmm excellent [= the main thing though, is it worth it?
  5. nsladden
    nsladden GET UTED
    Murwillumbah
    Well first, you would need to find out just how easy it is to install & what needs to be done to fit it. (which is what you're trying to do now). Then you need to find out how much for the twin fan setup. Then you need to figure out how much can you do yourself?
  6. LowVp
    LowVp VP Enthusiast
    Dalby, Qld
    VP Ute 3.8T T56
    why, save yourself some money and just install a thermatic fan switch, i have a turboed 6 and the stock fan does the job just nicely
