Twin Piston Brake Calipers
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by Archers, Jul 10, 2008.
  1. Archers
    Archers New Member
    ADELAIDE
    Ve Calais V 6ltr
    ay guys just a quickie i have a vx v6 and was wondering if i have TWIN PISTON BRAKE CALIPERS i checked and looks like i dont but i dont really know about this sort of thing thanxs for the help
  2. dijm8
    dijm8 What You Looking At
    VZ SS LS3
  3. VrWagz1
    VrWagz1 The Wagon on Wheels..
    wollongong
    VE SSV MY09 Auto Wagon
    Im 99% sure thats all they come with at a minimum, if you have anything else it would be better not worse. You could search ebay for the calipers and you'll get some pics there to compare.
  4. VL Berlina 5speed
    VL Berlina 5speed Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    vt onwards have them, so yes you do
    heres a pic if you want to compair too just to make double kazillion sure (left is vt twin spot on vt disc, right is vl rear single spot on disc)
  5. f1_power
    f1_power New Member
    Adelaide, South Australia
    VXII Berlina Sedan
    All VXs should have 2 piston calipers on front brakes but only 1 on the rear.
    I could be corrected on this though!
  6. Archers
    Archers New Member
    ADELAIDE
    Ve Calais V 6ltr
    wow thanxs for the fast reply guys i guess i do mine are the same as the pic from vl berlina sent me so thanxs again guys
  7. adam69
    adam69 Banned
    VT Clubby
    ALL VT on have twin piston fronts,standard.
  8. Holdens Rule
    Holdens Rule New Member
    VT Calais V6
    Bit off the topic but has anyone seen the front brakes on a series 1 AU? I've seen bigger calipers on motor scooters! Go holdens
  9. Calaber
    Lower Hunter Region NSW
    CG Captiva 5 Series 2
    When the VT was released, it was a lot heavier than the VS (about 150kg more) and everybody with standard VN-VS brakes would know how inadequate they were. Holden knew that the VT had to be equipped with much bigger and better brakes. Standard brakes were twin piston front, single rear, with larger diameter and thicker discs front and rear, even on a base Exec.
    Sports and V8's brakes were beefed up again from the Exec standard. It's just a pity they didn't sort out the disc warping problem that has afflicted VT-VZ's from day one.
  10. RVN 355
    RVN 355 New Member
    WEST SUBS
    91 VN SS 355
    yes the vx has twin piston calipers and ABS brakes (Bosch 5.3)
