enroh
- Jun 27, 2010
- 528
- 8
- 18
- Location
- Regional S.E. QLD
- VY SS UTE, 69 CAMARO!
Hey Guys,
I'm dead keen on building my vx berlina auto into a twin turbo sleeper before powercruise 37. Short time frame I know.
Anyway, just keen on getting useful and productive information and advise from anyone that has fitted turbos (single or twin) to their ls.
My plans are as it stands
-stock motor with dual valve springs
-reversed standard manifolds with 2 1/4 feed pipe
-x2 gt2871 turbos -(cheap bush-type)
-2 1/2 stainless dump pipe
-510x230x65 intercooler
-50mm int-inlet piping
-65mm oulet with 100mm expander into t/b
-60lb injectors
-2 bar map sensor
-intercooler spray
-water/meth injection (if time permits....)
-inline manual boost controller
-cheap bovs plumbed back
etc etc
-also need to convince the boys at hi-torque to dyno tune it for me.....
I want 400+rwhp so i'll probably set it at around 7-10psi, i'll keep it conservative for the first coupla days of powercruise, then wind it up to 12psi on sunday and see how she goes...lol, im not to worried if she goes pop, cuz then its an excuse to stroke it....
any info and technical advice would be greatly appreciated. even info on the seemingly simple and obvious things would be great... like where did you put your iat sensor???(and how'd you keep it in against boost pressure?...)
etc etc.
Cheers, enroh
-60lb injectors
-2 bar map sensor
-intercooler spray
etc etc
etc etc.
Cheers, enroh
