Tyre wear on VR - VS IRS ?
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by sixshooter, Jul 30, 2005.
  1. sixshooter
    sixshooter New Member
    2x VS
    After reading RKZ234 's post about his VX tyre wear issues...
    I started to become concerned as to whether any of the IRS VR - VS Commodores or Statesmans suffer from the same bad tyre wearing problems.
    If anyone has experienced bad tyre wear on these models I'd appreciate if they could post a reply as I am considering either a VS Calais or Statesman as my next car...
    I am also considering the Berlina aswell.....which in my opinion is just a Calais with a solid rear end.
    Except lately I've seen alot of VS Berlina's advertised with IRS...
    Is IRS standard on the VS model Berlina ?
    Either way... if this post generates bad replies for IRS I will narrow my car search for a Berlina without IRS...
    TIA
    sixshooter :wave:
  2. cizocizo
    cizocizo Guest
    no probs for me with the irs :)
  3. hispeedvp
    hispeedvp VP SS Ute
    W.A
    VP Group A Ute
    many people neglect there cars and forget how important it is to get a four wheel alignment. sure a lot of people get a front wheel alignment done but how often do you do all four. every 2 to 3 months i get wheels ballenced and aligned, this will premote better tyre where, i have also heard if you have IRS and lower you car an adjustable panhard rod should be fitted.
  4. cizocizo
    cizocizo Guest
    absolutley. look at most lowered commodores you can see the tyres on a completely different angle to the front.
    2 point camber kit is also another option for fixing such things
  5. Raging Bull
    Raging Bull New Member
    VX S Pack L67
    I haven't had really had any tyre wear problems but I don't really pay attention having 205s and 215s on, I'd be alot more concerned having rims on. Lowering is a problem, you'll need a camber kit otherwise goodbuy tread.
    IRS is not standard on Berlinas, it was an option but you'll probably find most Berlinas with IRS but there are some with live axle.
  6. VSIIBerlinaL67
    VSIIBerlinaL67 New Member
    VX SS M6
    IRS on berlinas was an option
  7. BlackVXGTS
    BlackVXGTS Well-Known Member
    Melbourne, SE
    The rod is only required if you lower a commodore with a live axle. Not required for an IRS vehicle.
  8. sixshooter
    2x VS
    I was thinking the same thing !
    Thanks to everyone for input to this thread :thumbsup:
  9. fixxxer
    fixxxer Member
    VF SV6
    No problems with my IRS, tyre wear is normal, even the way i drive :)
    Car isnt lowered, just standard FE2
  10. soulyouth
    soulyouth Space Docker
    Bossley Park
    Sold for scrap :(
    I do
    Hi I have a 94 VR Calais IRS, standard 15" calais rims, and with the lovell superlow springs in the back I have had heaps of uneven tire wear, I think is is due to the lack of upper control arms which are a must for lower IRS VR-VS's.
    But my new airbag set up should take of of this, will post pics when complete
  11. Fekason
    Fekason Fekason
    Penrith NSW
    Slight Increase
    My rear tyres in the VS S2 IRS wear a little extra on the inside. Tyre rotation keeps it "managable".
    Front wears well if wheel alignment kept within limits.
    I have a camber kit to fit, but have not got around to it yet.
  12. Smitty
    Smitty Well-Known Member
    Bayside Melbourne
    Gen-F R8 Tourer wagon, VK Clubbie race car
    I have a VR Berlina 185i 5.0 auto with IRS ABS LSD and FE2
    rear tyre wear is not an issue...never has been (missus drives it)
    I rotate tyres F<->R every 10,000 and get 60,000 out of a
    set of tyres (it has 16x8 Clubbie wheels and Jap Sumitomo tyres on it atm)
    hth
    cheers
  13. No Irs Problems On The Ss If Anything The Front Is Worse Than Back
  14. Demons1964
    Demons1964 Member
    SE Melbourne
    VY Calais, WHII Statesman V8, VC L 202
    VSII V8 Stato with IRS at standard ride height. No issues at all with rear tyre wear. Current set has 50,000km on them and still has good even tread depth. Car does mostly freeway driving but I imagine those with lowered suspension that do a lot of cornering would have the most problems. Did (and still have) 1 tyre that was out-of-round on the front. Moved it to the rear and much less noticeable.
  15. Mate What Size Tyres Do U Have On The Statsman And What Type? I Have Done 30,000k's On Potenza So3 18'' Rims And Need New Ones But Not For $350 A Tyre
  16. junglefeet
    junglefeet Guest
    my vs calais wears quicker on the insides. ive asked about rear wheel alignments and been told that they dont do em...maybe been bumsteered again eh?
  17. Demons1964
    Demons1964 Member
    SE Melbourne
    The missus has got the car at the moment, so can't remember the exact details. They're on the standard 16" stato rims that came with the car, and are probably the same width/profile as was sent from the factory. I can get the exact brand and profile for you if interested but it's probably not much help to those with low profile tyres. And at only $160 per tyre when I bought them, combined with how far they've travelled I can understand why you're bleeding.
