under 100,000 and new engine needed
Discussion in 'VE Holden Commodore (2006 - 2013)' started by ssv styles, Oct 4, 2014.
  1. ssv styles
    ssv styles New Member
    PERTH
    MY9.5 VE SSV
    My 09 ssv has just ticked over 98,000kms. Started it at work last week and straight away started making a hell of a racket. Almost a skuffing, grabbing sound. Oil pressure and level perfect. Got it towed to holden and turns out it was camshaft and lifter failure! And it must have done some damage as its getting another motor installed (under warrenty thank f**k.) How it was running fine when i switched it off at the start of the day, then come lunch after a second of idleing it turns to custard, i just dont know. Oil and filter changed 400 kms ago. Is this a problem the ls2 is known for or some other reason.. has me stumped.
  2. arronm
    arronm Active Member
    FPV F6 VF Redline WGN
    Lucky warranty...
  3. ssv styles
    PERTH
    MY9.5 VE SSV
    Yea mate i dont wana imagine what it would of cost me..
  4. acarmody
    acarmody Donati..Whoa Green
    VX Berlina
    Bloody hope they are installing a new crate motor and not some unknown condition second hand one.
    Sounds like oil didn't make it to the lifters or cam.
  5. ssv styles
    PERTH
    MY9.5 VE SSV
    Not sure mate but ive told them id rather a new one than an unknown rebuilt item.
  6. acarmody
    VX Berlina
    They won't use a rebuilt one. The dealership will get Holden to pay for it under warranty, engine and labour. But I'm not sure if they use a new motor or a "equal condition" motor. Ask the dealership. Kick up a stink if its a used motor.
  7. UFO
    UFO I Believe
    MY10 VE International Sportwagon SIDI 3L
    Who did the oil change mate?
    Was it the dealer?
    No way these engines should be giving up at 100k.
    At least you've got the warranty to rely on, otherwise that would have been one expensive repair bill!
    Others have posted that you should demand a new engine (vs a recon), but how do you ensure that's the case? Trust the dealer?
  8. acarmody
    VX Berlina
    I would simply ask to see it, either when the engine arrives, or when its being fitted.
    Obviously they would use all the old engines accessories (power steering pump, alternator, A/C, etc) though.
  9. PIR4TE
    PIR4TE Banned
    AWOL with Ari
    Black Pearl
    $3000, is not cheap, about same cost as trans recond or diff replacement, would say either of those are more common in an SS that's done sub 100k. Is rims and tyre spend in the large scheme of things, but a huge bonus for you both not having to pay and having the benefit for resale.
  10. ssv styles
    PERTH
    MY9.5 VE SSV
    The chrisler jeep and dodge dealer i got it from changed the oil. The warrenty isint the new car warranty but one i payed a few grand for when i brought it.
  11. PIR4TE
    PIR4TE Banned
    AWOL with Ari
    Black Pearl
    Mate you really need to get a better handle on exactly what the insurer's assessor (warranty provider) has determined will cover the dealer's arse, in practical terms. The dealer's head mechanic is not the third party insurance claims authority, but he can tell you what work and parts has been approved. Consider that the dealer stuffed up last service also, best to have that mindset than sharing the notion from the dealer that these cars have been known to blow up under 100k km every now and then.
  12. Ian Johnston
    Ian Johnston Active Member
    Mount Gambier, SA
    2015 Subaru Forester, XR6 turbo ute.
    Is it auto or manual?? AFM? And, its not an LS2.
    If AFM, they do have problems at times with lifter failure.
  13. ssv styles
    PERTH
    MY9.5 VE SSV
    Manual non AFM.
  14. ssv styles
    PERTH
    MY9.5 VE SSV
    Thanks pirate yea i got the head of the service department from the dealership to ring the bloke im dealing with from holden and explain what my warrenty t&cs are cos i was sick of being the middle man relaying messages between them. This is the reason id much rather take care of my own oil changes. But like u say it could just be a fault with those particular engines as ive herd that from a few people.
  15. brasher
    brasher New Member
    Aus
    VE SSV Ute
    even if it's manual if it's a L77 the AFM rubbish is still there unfortunately.
  16. SSVSE
    SSVSE New Member
    nsw country
    my10 SSV SE L76
    AFM is NOT 'rubbish' mate !
  17. brasher
    brasher New Member
    Aus
    VE SSV Ute
    lol ok
    brb saving 1L/100km, brb buying a veyron, brb lifters failed and scored cam
  18. ssv styles
    PERTH
    MY9.5 VE SSV
    I was going through some old posts and it seems the MY9.5 commodores which mine is, were fitted with an L98? Does this engine have AFM?
  19. Reaper
    From personal experience, I have zero trust in GM lifters. This failed lifter wiped the lobe off the cam and things went very down hill from there (LS3 in this case) but I've heard instances of it happening on all the LS series motors.
  20. Robbo VS3
    Robbo VS3 Member
    In The Sticks NSW
    VE SSV PHANTOM
    All Series 1 Manual VE's have the L98 with no AFM. The 06 to 08 VE auto's also had the L98 with no AFM.
